Reply
DGN2200 VPN question about versions
ta123
I am looking to buy the above router as I need a router with VPN. But I cannot understand if it has VPN or not. This page lists two versions of the router: http://support.netgear.com/app/products/family/a_id/19723. V1 mentions VPN in the User Manual while V3 does not. Some Internet shops list it as with VPN and others - without.
Message 1 of 16
jmizoguchi
Virtuoso
Re: DGN2200 VPN question about versions
Some model on DGNxxx later add the VPN in the firmware
Go support.netgear.com and check.
If any firmware notes shows no added in do in VPN and products page say there is VPN and it has VPN from initial firmware
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 16
ta123
thanks a lot!
Message 3 of 16
ta123
I am now trying to configure VPN on that router. I am looking at the user guide from this page http://support.netgear.com/app/products/model/a_id/13012 and cannot figure out how to do it. It has a chapter on how to do it but all the addresses in the text and on the screenshots are different which makes it very confusing. Basically I need to set up VPN to able to connect to my home network from my office and I cannot do it. Is there any easy to follow how-to to do it?
Message 4 of 16
jmizoguchi
Virtuoso
Concept is all the same
You would not find the same model casestudy at my site but there is plenty to look and learn
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 5 of 16
ta123
I wonder if I must use Netgear ProSafe with this router or it does not matter. I'm on Ubuntu which has openswan.
Message 6 of 16
ta123
Got this in the log:
Jul 31 22:38:48.532 xl2tpd[11763]: death_handler: Fatal signal 15 received
Jul 31 22:38:48.532 Stopping xl2tpd: xl2tpd.
Jul 31 22:38:48.553 ipsec_setup: Starting Openswan IPsec U2.6.37/K3.2.0-27-generic...
Jul 31 22:38:49.015 ipsec__plutorun: Starting Pluto subsystem...
Jul 31 22:38:49.020 ipsec__plutorun: adjusting ipsec.d to /etc/ipsec.d
Jul 31 22:38:49.030 recvref[30]: Protocol not available
Jul 31 22:38:49.031 xl2tpd[11929]: This binary does not support kernel L2TP.
Jul 31 22:38:49.031 Starting xl2tpd: xl2tpd.
Jul 31 22:38:49.031 xl2tpd[11932]: xl2tpd version xl2tpd-1.3.1 started on myasus PID:11932
Jul 31 22:38:49.031 xl2tpd[11932]: Written by Mark Spencer, Copyright (C) 1998, Adtran, Inc.
Jul 31 22:38:49.032 xl2tpd[11932]: Forked by Scott Balmos and David Stipp, (C) 2001
Jul 31 22:38:49.032 xl2tpd[11932]: Inherited by Jeff McAdams, (C) 2002
Jul 31 22:38:49.033 xl2tpd[11932]: Forked again by Xelerance (www.xelerance.com) (C) 2006
Jul 31 22:38:49.033 xl2tpd[11932]: Listening on IP address 0.0.0.0, port 1701
Jul 31 22:38:49.053 ipsec__plutorun: 002 added connection description "Office"
Jul 31 22:39:59.685 104 "Office" #1: STATE_MAIN_I1: initiate
Jul 31 22:39:59.685 003 "Office" #1: ignoring informational payload, type NO_PROPOSAL_CHOSEN msgid=00000000
Jul 31 22:39:59.685 003 "Office" #1: received and ignored informational message
Jul 31 22:39:59.685 010 "Office" #1: STATE_MAIN_I1: retransmission; will wait 20s for response
Jul 31 22:39:59.686 003 "Office" #1: received and ignored informational message
Jul 31 22:39:59.686 010 "Office" #1: STATE_MAIN_I1: retransmission; will wait 40s for response
Jul 31 22:39:59.686 003 "Office" #1: ignoring informational payload, type NO_PROPOSAL_CHOSEN msgid=00000000
Jul 31 22:39:59.686 031 "Office" #1: max number of retransmissions (2) reached STATE_MAIN_I1. No response (or no acceptable response) to our first IKE message
Jul 31 22:39:59.686 000 "Office" #1: starting keying attempt 2 of at most 3, but releasing whack
Jul 31 22:39:59.698 [ERROR 300] 'IPsec' failed to negotiate or establish security associations
Message 7 of 16
jmizoguchi
Virtuoso
IPsec is IPsec so generally you can
see my site one case study I have for linux.
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 8 of 16
ta123
OK, yesterday i managed to establish DNG-to-DNG VPN tunnel and everything worked absolutely fine. I could connect and drop the connection without any problem. Today the connect button does not work at all and I cannot establish the tunnel. I am so frustrated.
Message 9 of 16
jmizoguchi
Virtuoso
power on/off the unit and test again and MTU also needs to be 1430
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 10 of 16
ta123
It does not look to help. Got this in teh logs of the local router:
Thu, 2012-08-02 17:22:29 - [MyHome] initiating Main Mode to replace #5
Thu, 2012-08-02 17:22:39 - [MyHome] STATE_MAIN_I1: retransmission; will wait 20s for response
Thu, 2012-08-02 17:22:59 - [MyHome] STATE_MAIN_I1: retransmission; will wait 40s for response
Message 11 of 16
jmizoguchi
Virtuoso
if you are using dynamic DNS make sure dyndns account has correct public ip
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 12 of 16
ta123
Thanks a lot for your responses. One router has a fixed IP and another is dynamic. I actually need to initiate teh VPN tunnel from home (dynamic IP) to the office (static IP). I do not really need to to it the way around. Do I really need static IPs on both sides?
Message 13 of 16
jmizoguchi
Virtuoso
doesn't matter the direction
ipsec is ip to ip so if dyndns report different IP then it can cause issues .'
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 14 of 16
ta123
Thanks a lot. Do you know if DGN2200 works with any other services than DynDNS?
Message 15 of 16
jmizoguchi
Virtuoso
No..............
What you see in router GUI is only choice
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 16 of 16
Top Contributors
Discussion stats
  • 15 replies
  • 6893 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
