Reply
DGN2200 issue - No network access
btprabhu
Follower
Hi,
I have brought a brand new netgear DGN2200. I have DSL connection too. But when I power on the router initially the power LED was red and then turned to green and I was able to access the admin page for a minute, after that it suddenly turned red and entire physical network access to PC is down. This happens always. I don't know what is the issue ? I suspect device malfunction. Sometimes after the reboot, I see no LED light after the initial green color blink of all the port LEDs and power LEDs in RED.Please help.
Thanks,
Prabhu
Message 1 of 2
Joe_
Apprentice
Re: DGN2200 issue - No network access
Right off I would say that the unit is faulty. Since you just bought it, I would also say that you should return it straight away.
According to the online User Manual here, there is one more thing you could try, and that's to reset the unit to Factory Defaults. Check for that procedure in this same manual.
Message 2 of 2
Discussion stats
  • 1 reply
  • 2458 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
