Reply
DGND3300v2 seeing mw3 as DOS attack?
jon3sy9
im having very bad hit detection using this router on MW3 and when i check my logs i get this
Tue, 2012-07-17 12:09:06 - UDP Packet - Source:89.240.175.141,26863 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:06 - UDP Packet - Source:97.85.70.143,14558 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:07 - UDP Packet - Source:222.155.149.205,3074 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:07 - UDP Packet - Source:176.61.14.81,3074 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:07 - UDP Packet - Source:86.130.146.197,50874 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:07 - UDP Packet - Source:180.94.186.142,3074 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:07 - UDP Packet - Source:116.49.232.60,2124 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:08 - UDP Packet - Source:87.177.56.111,61566 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:08 - UDP Packet - Source:89.240.175.141,26863 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:08 - UDP Packet - Source:123.203.127.89,3074 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:08 - UDP Packet - Source:217.88.52.107,3074 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:08 - UDP Packet - Source:93.145.144.215,3074 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:08 - UDP Packet - Source:80.132.76.77,3074 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:08 - UDP Packet - Source:92.12.211.183,3074 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:09 - UDP Packet - Source:58.169.209.218,47712 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:09 - UDP Packet - Source:99.162.255.10,3074 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:09 - UDP Packet - Source:123.203.127.89,3074 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:09 - UDP Packet - Source:124.146.87.101,3074 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:09 - UDP Packet - Source:217.88.52.107,3074 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:09 - UDP Packet - Source:89.240.175.141,26863 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:09 - UDP Packet - Source:78.146.27.39,3074 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:10 - UDP Packet - Source:109.76.181.55,10001 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:10 - UDP Packet - Source:80.132.76.77,3074 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:10 - UDP Packet - Source:93.145.144.215,3074 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:10 - UDP Packet - Source:87.177.56.111,61566 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:10 - UDP Packet - Source:92.12.211.183,3074 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:10 - UDP Packet - Source:186.209.15.44,4178 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:10 - UDP Packet - Source:188.60.254.72,3074 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:11 - UDP Packet - Source:109.76.181.55,10001 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:11 - UDP Packet - Source:90.210.60.6,3074 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:11 - UDP Packet - Source:98.145.21.111,3074 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:11 - UDP Packet - Source:188.60.254.72,3074 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:11 - UDP Packet - Source:89.240.175.141,26863 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:12 - UDP Packet - Source:58.169.209.218,47712 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:12 - UDP Packet - Source:92.12.211.183,3074 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:12 - UDP Packet - Source:71.45.52.173,3074 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:12 - UDP Packet - Source:186.209.15.44,4178 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:13 - UDP Packet - Source:90.218.151.18,3074 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:13 - UDP Packet - Source:98.145.21.111,3074 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:13 - UDP Packet - Source:115.64.72.125,3074 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:13 - UDP Packet - Source:90.210.60.6,3074 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:13 - UDP Packet - Source:81.129.115.171,3074 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:13 - UDP Packet - Source:71.84.104.181,3074 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:14 - UDP Packet - Source:82.251.27.138,29011 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:14 - UDP Packet - Source:2.216.189.43,3074 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:14 - UDP Packet - Source:92.12.211.183,3074 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:14 - UDP Packet - Source:115.64.72.125,3074 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:14 - UDP Packet - Source:114.78.191.138,3132 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:14 - UDP Packet - Source:217.210.139.203,37145 Destination:192.168.0.100,3074 - [DOS]
Tue, 2012-07-17 12:09:14 - UDP Packet - Source:66.169.239.91,3074 Destination:192.168.0.100,3074 - [DOS]
any advice as to why its doing this?
Message 1 of 9
jmizoguchi
Virtuoso
Re: DGND3300v2 seeing mw3 as DOS attack?
most game uses many of server and cause router to see an attach.
put on DMZ to bypass they firewall
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 9
jon3sy9
the xbox has always been in the dmz?
Message 3 of 9
jmizoguchi
Virtuoso
what with question ?.... you have on DMZ already?
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 9
jon3sy9
yes my xbox has always been in the DMZ ip address 192.168.0.100 so i dont understand why its getting [DOS] message 6 times per second?
Message 5 of 9
jmizoguchi
Virtuoso
diable upnp in the outer setting
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 6 of 9
jon3sy9
ok i'll give it a try and let you know how things go...thanks for the help
Message 7 of 9
jon3sy9
Wed, 2012-07-18 23:25:00 - UDP Packet - Source:98.224.109.52,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:00 - UDP Packet - Source:70.170.74.70,3167 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:00 - UDP Packet - Source:74.195.118.127,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:00 - UDP Packet - Source:76.173.97.171,46148 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:00 - UDP Packet - Source:66.176.223.110,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:00 - UDP Packet - Source:173.67.36.139,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:01 - UDP Packet - Source:70.228.94.4,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:01 - UDP Packet - Source:98.224.109.52,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:01 - UDP Packet - Source:94.4.168.192,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:01 - UDP Packet - Source:189.250.85.89,21029 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:02 - UDP Packet - Source:86.42.201.235,10003 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:02 - UDP Packet - Source:189.158.44.155,23506 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:02 - UDP Packet - Source:173.67.36.139,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:03 - UDP Packet - Source:70.228.94.4,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:03 - UDP Packet - Source:70.135.105.158,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:03 - UDP Packet - Source:98.224.109.52,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:03 - UDP Packet - Source:68.3.224.4,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:19 - UDP Packet - Source:97.101.143.169,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:19 - UDP Packet - Source:174.92.186.35,35731 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:19 - UDP Packet - Source:99.224.156.146,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:19 - UDP Packet - Source:66.229.80.239,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:19 - UDP Packet - Source:67.172.55.210,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:19 - UDP Packet - Source:190.58.177.21,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:20 - UDP Packet - Source:96.55.182.157,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:20 - UDP Packet - Source:174.92.186.35,35731 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:20 - UDP Packet - Source:99.224.156.146,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:20 - UDP Packet - Source:66.229.80.239,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:20 - UDP Packet - Source:189.158.44.155,23506 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:20 - UDP Packet - Source:24.16.116.34,40785 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:20 - UDP Packet - Source:66.65.53.229,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:21 - UDP Packet - Source:75.192.172.173,57345 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:21 - UDP Packet - Source:189.158.44.155,23506 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:21 - UDP Packet - Source:24.16.116.34,40785 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:21 - UDP Packet - Source:24.117.61.213,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:21 - UDP Packet - Source:69.242.168.97,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:22 - UDP Packet - Source:173.67.36.139,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:22 - UDP Packet - Source:97.101.143.169,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:22 - UDP Packet - Source:70.135.105.158,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:22 - UDP Packet - Source:24.144.23.209,60973 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:22 - UDP Packet - Source:71.197.16.159,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:22 - UDP Packet - Source:76.89.112.87,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:22 - UDP Packet - Source:24.117.61.213,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:23 - UDP Packet - Source:173.67.36.139,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:23 - UDP Packet - Source:24.144.23.209,60973 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:23 - UDP Packet - Source:70.135.105.158,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:23 - UDP Packet - Source:99.69.107.103,49603 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:23 - UDP Packet - Source:71.197.16.159,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:23 - UDP Packet - Source:66.65.53.229,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:24 - UDP Packet - Source:99.69.107.103,49603 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:24 - UDP Packet - Source:66.65.53.229,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:24 - UDP Packet - Source:68.3.224.4,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:24 - UDP Packet - Source:96.55.182.157,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:24 - UDP Packet - Source:24.117.61.213,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:25 - UDP Packet - Source:173.80.248.209,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:25 - UDP Packet - Source:68.33.173.177,18215 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:25 - UDP Packet - Source:68.60.92.52,19203 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:25 - UDP Packet - Source:70.228.94.4,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:25 - UDP Packet - Source:24.144.23.209,60973 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:25 - UDP Packet - Source:70.135.105.158,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:25 - UDP Packet - Source:69.242.168.97,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:25 - UDP Packet - Source:24.117.61.213,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:25 - UDP Packet - Source:68.226.80.183,11471 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:26 - UDP Packet - Source:24.91.133.30,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:26 - UDP Packet - Source:173.80.248.209,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:26 - UDP Packet - Source:68.33.173.177,18215 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:26 - UDP Packet - Source:68.60.92.52,19203 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:26 - UDP Packet - Source:90.206.46.177,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:26 - UDP Packet - Source:69.242.168.97,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:28 - UDP Packet - Source:173.80.248.209,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:28 - UDP Packet - Source:68.33.173.177,18215 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:28 - UDP Packet - Source:24.11.112.111,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:28 - UDP Packet - Source:68.60.92.52,19203 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:28 - UDP Packet - Source:68.61.76.223,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:28 - UDP Packet - Source:90.206.46.177,3074 Destination:192.168.0.100,3074 - [DOS]
Wed, 2012-07-18 23:25:28 - UDP Packet - Source:69.242.168.97,3074 Destination:192.168.0.100,3074 - [DOS]
this is with upnp unchecked?
Message 8 of 9
jmizoguchi
Virtuoso
btw... you do not need post mile long log.. few line would be fine for most user to understand.
disable either SPI or DoS under wan setup
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 3426 views
  • 0 kudos
  • 2 in conversation
Announcements
