Reply
Highlighted
DGND3700v2 and Jitter?
After 4 long years of service, my Netgear DG834G packed in. To replace it, I recently purchased the Netgear N600 DGND3700v2 wireless router.
Since then, I am suffering from really high jitter which makes Skype calls and Online gaming intolerable.
This is what I would typically get with the DG 834G:
And this is what I have gotten for the past 3 days and what I got just 1 minute ago:
I don't use wireless and my PC is connected to the internet via the same Powerline adapters as my DG 834G was.
Can someone explain to me why this newer, 'better' and twice as expensive router is raping my connectivity and tell me if there is anything that I can do about it?
THX.
Message 1 of 5
Highlighted
Virtuoso
Re: DGND3700v2 and Jitter?
duplicate
http://forum1.netgear.com/showthread.php?t=82040
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 5
Highlighted
Apprentice
You are in the wrong forum buddy. If you look in the correct forum you will see there are mucho persons that have issues with both the v1 and v2.
Message 3 of 5
Highlighted
Ok cheers....
Well, if the thing doesn't do what it says on the tin then I guess it goes back to the shop...
jeeezus...here we go.
Message 4 of 5
Highlighted
jmizoguchi wrote:
duplicate
and in the wrong forum....
I have reposted it in the correct forum.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3215 views
  • 0 kudos
  • 3 in conversation
Announcements
