Reply
DHCP Client not found in settings
marine76
WNDR3400V3, Firmware V1.0.1.24_1.0.67, Windows 8.1, using as AP.
Where can I find DHCP Client Enable/Disable in the settings for this router?
Model: WNDR3400v3|N600 Wireless Dual Band Router
Message 1 of 2
antinode
Guru
Re: DHCP Client not found in settings
> [...] using as AP.
  As in ADVANCED > Advanced Setup > Wireless Settings > AP Mode?
   Selecting "AP Mode" should disable the DHCP server without your doing
it explictitly.
   Although you shouldn't need it for this, according to the WNDR3400v3
User Manual, the DHCP server stuff should be situated under
ADVANCED > Setup > LAN Setup.
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Read.
   You have to admire the clarity of a user interface with both:
      ADVANCED > Setup
and
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 380 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
