Reply
DNS error connecting to Cisco cable modem
dgone
Okay, I keep getting a DNS error on my WNR1000 yet I don't have the same problem with my WGR614 v9 when connected to my cable modem. The lights on the WNR1000 seem fine to me, but the main problem is the DNS error that I keep getting.
Message 1 of 9
jmizoguchi
Virtuoso
Re: DNS error connecting to Cisco cable modem
try test using google DNS on pc side and see ...
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 9
dgone
Tried it, so far, it results in a dns error when I go to google on the WNR1000. While it's connected to the WGR614 v9, it works fine and google shows up correctly.
Message 3 of 9
jmizoguchi
Virtuoso
You did put google DNS on pc side and NOT on router correct?
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 9
dgone
No, changing the DNS to Google DNS does not work.
Message 5 of 9
dgone
And the computer connects just fine to google and the goodle dns without the router.
Message 6 of 9
jmizoguchi
Virtuoso
test without router don't solve anything
you need to TEST google DNS on PC SIDE behind the router- This for TEST PURPOSE. Do NOT put google DNS on ROUTER
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 7 of 9
dgone
I already said that the google dns test works with the pc.
Message 8 of 9
dgone
The PC can connect to the DNS just fine... the problem is with the router.
Message 9 of 9
Discussion stats
  • 8 replies
  • 3384 views
  • 0 kudos
  • 2 in conversation
Announcements
