× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Device keeps connecting even after being blocked - R6400
secessit
Evidently, I posted this to the wrong discussion group, so this is a duplicate entry on the discussion group that was suggested.
On my Netgear R6400 with firmware V1.0.1.62_1.0.41 I have an amazon device that has joined my wireless network that I am not familiar with. I have tried to block the device using the Access Control List, but it continues to report that it is connecting to the network. When that occurs, I am able to ping the device. It appears that the block device feature on the R6400 is not working.
How do I keep the device from getting a DHCP address and jointing the network?
I would really like to be able to edit the DHCP table to remove it, but that does not appear to be possible on this router.
Model: R6400|AC1750 Smart WiFi Router
Message 1 of 3
Accepted Solutions
secessit
Re: Device keeps connecting even after being blocked - R6400
Thank you for the reply.  I did try this method but found that it did not work by simply blocking the MAC address. It did block access, but the MAC address was still assigned and IP address that was being blocked.  I wanted to eliminate it from be issued an IP address as well.  After doing a bit more research I found that once a device has been allowed it will continue to show up and be assigned an address even if blocked.
I resolved the issue by disallowing all new connections, changed the SSID password and blocked the offending MAC address.  After doing all this and then restarting the router, (and changing the passwords on all the allowed devices) I finally eliminated the access and indication of the unwanted device from my router.
As far as I am concerned, this issue is closed.
Message 3 of 3
All Replies
RVALENZ
NETGEAR Moderator
Try using mac filter. Check this link out if it helps. https://kb.netgear.com/13112/How-to-configure-Access-Control-or-MAC-Filtering-Smart-Wizard-routers
Rhys
Community Team
Message 2 of 3
secessit
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3068 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
