Reply
Dgn1000 Lan ports not working help
dunkykong
Hi there i recently aquired a DGN1000 wireless router a month ago as i joined orange broadband and it was working perfctly up until today i had been away for 2 days and had the router switched off but when i switched it on today the wireless still works and gives me internet but all 4 lan ports dont work i have tried them in a pc, laptop and a xbox 360 and get cannot obtain an ip address ect.
The devices seem to show that a wire is connected but cant give access to the internet or the routers set up page ect does anyone know where i may have went wrong or what could be done to solve this.
Thanks for looking
Dunkykong
Message 1 of 4
jmizoguchi
Virtuoso
Re: Dgn1000 Lan ports not working help
can you ping the router and have IP from the router ?
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 4
dunkykong
Only when connected through wireless not when using through lan ports.
Message 3 of 4
jmizoguchi
Virtuoso
sounds like bad lan ports.
some of these DGN series goes bad with capacitor inside and make defective LAN ports
reset doesn't fixe it which likely not, I would look for new route unless unit is still under warranty
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2686 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
