Reply
Difference in model RBR50 and RBK753S
ringrum
Follower
What is the difference between teh Orbi RBR50 and teh RBK753SR
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Guru
Re: Difference in model RBR50 and RBK753S
the 50 series are AC routers.
the 700/800 series are AX router.
There's a few other differnces such as ethernet ports speeds/etc but the AC--->AX is the key.
https://www.netgear.com/support/product/RBR50.aspx
https://www.netgear.com/support/product/RBR750
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 2
Discussion stats
  • 1 reply
  • 307 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
