- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Disconnecting issues 6900v2
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have searched in here looking for a answer, it seems since I updated to the newest firmware, even the beta R6900v2-V1.2.0.14_1.0.1_beta, the router diconnects all the time if there is any inactivity. I know its the router because I have a external drive attached to it and it won't connect either. Anyone have any suggestions? I am at a lost here, I have reset the router, downloaded the earlier firmware R6900v2-V1.2.0.8_1.0.1 and nothing works.
TIA
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @medicdad73,
1. Please make sure you do a factory reset after updating the router's firmware.
2. Does it disconnect all your devices (wired and wireless)?
3. Have you tried reflashing the firmware?
Dexter
Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @medicdad73,
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Disconnecting issues 6900v2
Hi @medicdad73,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello, I'm experiencing same issues. I have done the factory reset and updated to the latest firmware as described above.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, no luck, had to put in old firmware. Had a update today and the samething happened, the router disconnects all devices and then locks up.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Still experiencing issues, did the reset nothing. Had another update today, same problems.
Had to reload older firmware
