Reply
Dynamic DNS setting as update client
mvestel
I am trying to get Dynamic DNS setting in my WNDR3700 router to work. right now when i press "show status" it says "Dynamic DNS servise is NOT enabled"
i have an account with dyndns.com.
I have a service configured with a username and password:
vestel.dyndns.com
mvestel
xxxxxx
i use the same service info in the settings of the router.
I've read the instructions. i think i'm doing that correctly.
I've also contacted the DYNDNS folks. they said i need to configure an update client to update my hostname. they say a router with this feature "update client" should work.
but its not working. any suggestions?
Message 1 of 2
Frippi
Re: Dynamic DNS setting as update client
I never had any issues with dyndns on this router. All I did was:
1. Checked "Use a Dynamic DNS Service" option.
2. Entered hostname, username and password.
3. Clicked Apply.
You should probably double check everything:
1. Correct username, host and password.
2. Host configuration on DynDns site.
Message 2 of 2
Discussion stats
  • 1 reply
  • 2860 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
