Reply
Ethernet Dropouts
kturcotte
Ethernet Dropouts
I have the WNDR3700 V2, with the latest firmware, and it's been running great for months. Now all of a sudden it's sometimes dropping ethernet connectivity. Wireless continues to work fine (Tested on my 3DS and PS3), but wired it basically dead. Only way to fix it is to restart the router. I do have a switch after the router, and figured it *MIGHT* be that connection, so I moved everything major to the router itself, and it's still doing it. While it's doing it, I can't even get into the router configuration page (It just keeps trying to load, but never does). Any ideas?
Message 1 of 4
Simon0
Novice
Re: Ethernet Dropouts
Since you don't say which version of firmware, no idea. Perhaps port broken.
Message 2 of 4
kturcotte
It says it's running V1.0.0.8
Message 3 of 4
Simon0
Novice
you should do an RMA if the ethernet port fails.
Message 4 of 4
Discussion stats
  • 3 replies
  • 3832 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
