× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
External Netgear router R6300v2 vs. TimeWarner built-in router
500ford
Follower
Hello - Time Warner is switching out my old modem with their latest/fastest that has a built-in router; should I go with the built-in or deactivate & continue w/ the Netgear R6300v2?
Thank you
Message 1 of 2
Accepted Solutions
TheEther
Guru
Re: External Netgear router R6300v2 vs. TimeWarner built-in router
I would consider two factors in favor of keeping the R6300.
  1. It's a dual-band AC router. ISPs are slowly deploying dual-band AC routers. If the Time Warner replacement isn't one, and you have AC clients, then this may be reason enough to keep the R6300. Of course, you can repurpose the R6300 as an Access Point.
  2. Exclusive admin control. An ISP will always have admin access to their router. While it's highly unlikely that one of their employees would ever snoop on your network, why run that risk?
Message 2 of 2
All Replies
TheEther
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3396 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
