Reply
FATAL FIRMWARE UPGRADE ...... AVOID 1.0.4.28 version
sygibson
Tutor
ABSOLUTELY DO NOT USE FIRMWARE VERSION 1.0.4.28.
It is completley BUSTED - and because Netgear only supports their prodduct for 90 days - you are pretty much guaranteed to be SCREWED if it goes south.  I happen to have a pretty good idea of how to salvage a device firmware failure - and also got lucky to get it back working ... with only WASTING 2 HOURS of my time.
I just spent 2 hours fighting with my Netgear Nighthawk R9000 and external Motorola MB8600 Ultra Fast DOCSIS 3.1 Cable Modem.  I upgraded from 1.0.4.26 to .28.  The upgrade went smoothly.  But on reboot of the WiFi router, no Internet connection was estabilshed.  I went through the usual pain of unplugging LAN ports and plugging them back in, powering off the WiFi router and back on.  Powering WiFi Off, Motorola Off, wait 1 minute, then Motorola on, wait 10 mins, then Wifi ON ... 3 times.
I gave up and connected my personal cellular hotspot, downloaded the 1.0.4.26 version, backrevved the WifI Router, then went through 3 more power off/wait/power on cycles before the WiFi router would finally acquire connection to ISP.
ABSOLUTELY NOT SAFE FOR CONSUMPTION.
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 2
Re: FATAL FIRMWARE UPGRADE ...... AVOID 1.0.4.28 version
Duplicated over in the place where it really belongs:
FATAL FIRMWARE UPGRADE ...... AVOID 1.0.4.28 versi... - NETGEAR Communities
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 391 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
