× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
FIRMWARE VERSION UPDATES
Aguajera
Follower
I have never downloaded any of the firmware updates for my Ex6200 AC1200 bought in 2017. Must they be  installed in sequence or will the latest cover all previous versions?
Thanks in Advance
Model: EX6200v2|AC1200 Dual Band WiFi Range Extender
Message 1 of 3
Accepted Solutions
Guru
Re: FIRMWARE VERSION UPDATES
You can just install the latest. you don't have to install them in sequence.
Message 2 of 3
All Replies
Guru
Message 2 of 3
That usually works, but there are times when the updates are just too dramatic. Too much changes.
Try it first, and if that fails and if it doesn't work try something in the middle.
Where possible take this route:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1077 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
