Reply
Firewall on WNR2000v2 issues
json37
Follower
Trying to connect to a port on 192.168.1.2 from another PC on the network, I tried the external IP and internal, tried telneting to those ports. The firewall doesn't seem to be allowing them, I added all the ports in Port Forwarding to the correct IP. Even port 80 isn't working. They all work if I connect FROM the origin IP. Any ideas?
Message 1 of 3
jmizoguchi
Virtuoso
Re: Firewall on WNR2000v2 issues
wnr2000 is NOT super G routers. it is N routers
belong to
http://forum1.netgear.com/forumdisplay.php?f=33
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 3
jmizoguchi
Virtuoso
Lan to Lan do not require port forwarding
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2073 views
  • 0 kudos
  • 2 in conversation
Announcements
