Reply
Firmware update assistant
Samlin
Initiate
There is no "yes" button to click when the Firmware update assistant says I have an update available.
Model: R6400|AC1750 Smart WiFi Router
Message 1 of 3
noahleo
Re: Firmware update assistant
  • Connect a computer to the router using a coaxial cable to the Netgear firmware update.
  • Browse http://www.routerlogin.net and Enter your admin user name and password.
  • Select ADVANCED > Administration or Settings > Administration.
  • Select Firmware Update or Router Update by Clicking or tap Check.
  • The router searches for brand spanking new firmware.
  • Click or tap Yes for the firmware updates.
Message 2 of 3
Samlin
Initiate
Thank you for your response. The problem is that there is no "yes" button to click on the page where it asks if I want to update.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 448 views
  • 2 kudos
  • 2 in conversation
Announcements
