Reply
Firmware upgrade briked
LorenzS
Tutor
i have a router dgnd4000 briked after a firmware upgrade, does not respond on ethernet ports,  how can i restore the firmware with the internal serial port ?
thanks very much
Model: DGND4000|N750 Wireless Dual Band Gigabit ADSL2+ Modem Router
Message 1 of 6
LorenzS
Tutor
Re: Firmware upgrade briked
when i connect the serial cable i obtain this :
HELO
CPUI
L1CI
HELO
CPUI
L1CI
DRAM
PHYS
ZQDN
PHYE
DINT
LASY
USYN
MSYN
LMBE
PASS
ZBSS
CODE
DATA
L12F
MAIN
NAN0
BTam
0001
NAN9
NAN3
RFS0
NAN5
CFE version 1.0.38-112.14 for BCM96362 (32bit,SP,BE)
Build Date: 2012年 07月 20日 星期五 09:28:45 CST (sunny@localhost)
Copyright (C) 2000-2011 Broadcom Corporation.
NAND flash device: name <not identified>, id 0x92f1 block 128KB size 131072KB
External switch id = 53125
SC Debug: Setting RGMII TX_CLK DELAY at SWITCH IMP PORT!
SC Debug: Setting RGMII RX_CLK DELAY at SWITCH IMP PORT!
Chip ID: BCM6362B0, MIPS: 400MHz, DDR: 333MHz, Bus: 166MHz
Main Thread: TP0
Memory Test Passed
Total Memory: 134217728 bytes (128MB)
Boot Address: 0xb8000000
Board IP address                  : 192.168.1.1:ffffff00
Host IP address                   : 192.168.1.100
Gateway IP address                :
Run from flash/host (f/h)         : f
Default host run file name        : vmlinux
Default host flash file name      : bcm963xx_fs_kernel
Boot delay (0-9 seconds)          : 1
Board Id (0-5)                    : 96362ADVN2xh
Number of MAC Addresses (1-32)    : 11
Base MAC Address                  : 6c:b0:ce:72:b0:04
PSI Size (1-64) KBytes            : 24
Enable Backup PSI [0|1]           : 0
System Log Size (0-256) KBytes    : 0
Main Thread Number [0|1]          : 0
*** Press any key to stop auto run (1 seconds) ***
Auto run second count down: 0
Enter NMRP_main
Scanning Flash Section 0...
Sector number count 16
Scanning Flash Section 1...
Sector number count 304
Scanning Flash Section 2...
Sector number count 312
Scanning Flash Section 3...
Sector number count 320
Scanning Flash Section 4...
Sector number count 328
Scanning Flash Section 5...
Sector number count 336
Scanning Flash Section 6...
Sector number count 344
Scanning Flash Section 7...
Sector number count 352
Scanning Flash Section 8...
Sector number count 360
Scanning Flash Section 9...
Sector number count 376
Scanning Flash Section 10...
Sector number count 384
Scanning Flash Section 11...
Sector number count 416
Scanning Flash Section 12...
Sector number count 424
Scanning Flash Section 13...
Sector number count 432
Scanning Flash Section 14...
Sector number count 512
Flash Sector Number : 512.
Our ETH MAC:
6cb0ce72b004
NMRP:LISTENING
Enter NMRP_handle_LISTENING_state
### No NMRP Server found ###
    Sercomm Boot Version 1...0.1
Can not find  Block with Sercomm Sign!
Entering Download Mode : FW PID no exsit or corrupted.
In Httpdownload...
Message 2 of 6
antinode
Guru
> [...] does not respond on ethernet ports, [...]
   What, exactly, does that mean to you?  "respond" how, to what?
   A useful problem description would include an accurate, detailed
description of what you did, and of what happened when you did it.  As
usual, showing actual actions (commands) with their actual results
(error messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
> [...] how can i restore the firmware with the internal serial port ?
   Before trying anything with a serial port, I'd try the TFTP recovery
scheme.
      https://community.netgear.com/t5/x/x/m-p/1622096#M102004
   What did your Web search for terms like, say, "Netgear serial" find?
Message 3 of 6
LorenzS
Tutor
thanks for the reply, i will try to use TFTP
> [...] What, exactly, does that mean to you? "respond" how, to what?[...]
when i tried to upgrade the firmware the router stopped to work.
i can't ping the router throught lan port.
if i turn on the router the red led turns on and stays on and after 1 second the orange led turns on and off.
i have connect a jtag on serial port,  gnd, tx, rx, i turnon the router and on the terminal i obtain that list
Message 4 of 6
antinode
Guru
   "can't" is not a useful problem description.  It does not say what
you did.  It does not say what happened when you did it.  As usual,
showing actual actions (commands) with their actual results (error
   If the router is dead (all dead or mostly dead), then your computer
won't get a valid IP address (or other IP parameters) from the router's
DHCP server.  If your computer has no valid IP address, then "ping"
might fail.  The actual error message might be helpful.
   The TFTP recovery procedure instructions include configuring the
Ethernet interface on your computer with a static address (typically
"192.168.1.10") for exactly this reason.  If your router is only
_mostly_ dead, then a computer at an address like that should be able to
reach ("ping") the router (at "192.168.1.1").
Message 5 of 6
LorenzS
Tutor
i set the IP address  like this on the PC
IP address => 192.168.1.10
Subnet mask => 255.255.255.0
Default Gateway => 192.168.1.1
i connect the PC with a lan cable to the router Lan port  (not WAN)
if i ping 192.168.1.1 ( the router )  it's unreachable
the red  led o the router it's always on, the green led on the lan cable it's turn on, the orange led on the lan cable it's off
when i reboot the router it's turn on the red led and after 1 second the orange led turn on and turn of after 0,5 seconds
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 405 views
  • 1 kudo
  • 2 in conversation
Announcements
