Reply
Highlighted
Flashing over 1.0.0.32
Hi, I was trying to flash my v2 router from 1.0.0.32 to the newer builds and I'm unable to do this. Obviously tried from within the GUI with the upgrade firmware and that fails.. I then tried the TFTP instructions where you plug the PC directly into the router, assign it a static IP, reboot the router and then try to upgrade it with the new IMG file while it is still booting up (yellow power LED). That didn't work either as it would says it was erasing the flash but it never really did and then retry it until it said "unable to connect to server" and run out of attempts.
Any other ideas or suggestions on how to force feed a newer firmware on this thing?
Thanks
Message 1 of 2
Highlighted
Virtuoso
Re: Flashing over 1.0.0.32
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 8776 views
  • 0 kudos
  • 2 in conversation
Announcements
