- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
GS105v5
- Mark as New
- Bookmark
- Subscribe
- Permalink
GS105v5
I have never done this before i bought a 5port Ethernet cable out let i am getting lost
how do i add this as extra ports the ones on my Modem is not enough
Many thanks
Regard Jean
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: GS105v5
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
Look for the model number on the label on the device.
Begin with the Installation Guide.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Switches - NETGEAR Communities
I will ask the Netgear moderator to move your message.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: GS105v5
what actual device are you connecting the switch to?
You put "modem".
If its truly a modem only device, for most ISP's you can only connect a single device to it.
If you're wanting more connected, then you need a router or something to assign private IP addresses to.
So again, what modem/router/device are you connecting the switch to?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: GS105v5
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: GS105v5
@Wbhandball wrote:
I'm connecting to a router... they both worked fine until I replaced the router... one of them is ok.. the 2nd extender doesn't want to connect..
You'll have to tell us more.
You have a modem (which one?) feeding a router (which one?)?
The switch should be at the end of the chain, after the modem and router.
What is this "2nd extender"? The switch? Something else?
The word "extender" has special meaning in network world. It is usually something that extends the stretch of your wifi.
The more you can tell us the better. It cuts down how many questions you have to answer before we know what the problem might be.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: GS105v5
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: GS105v5
Hello so sorry i am still trying to work this out i have a optus modem it has all its ports full
so i bought gigabit ethernet swich so i could add another port i must be doing something wrong
as the computer i connected it to in another room doest work i have plugged the switch into our power
board put the ethernet cable in their and put the end in the computer please tell me where i am wrong
many thanks
Regards Jean
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: GS105v5
It sound like this anonymous Opus "modem" – there must be more than one model of Optus modem in the world – may be a modem/router. You said earlier:
Is that the same as the "optus modem"? If not you may be in classic "two routers" territory.
I don't understand this bit:
the computer i connected it to in another room doest work i have plugged the switch into our powerboard put the ethernet cable in their and put the end in the computer please tell me where i am wrong
What is this "power board"?
