Reply
GS308v3 Connection to router
IG_Cakewalk
Follower
So I have Synology RT2600ac connected to a netgear cable modem.  All is fine.  I can access the internet wirelessly and via ethernet if I am plugged into the router directly.  However, I installed an 8 port switch to allow me to make additional connections, and nothing plugged into the switch has internet access.
The current config is Cable modem > Wan port on Router.  Switch Port 8 to Router Lan port 4.  The computer I am using to post this is plugged into Lan port 1 on the router.  If I plug it, or anything else, into any port on the switch...no internet.
Any idea what I'm doing wrong here??
Thanks
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 283 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 6E
