Reply
Geschwindigkeit R6300V2
James08
Hallo
Ich habe eine 200/20 Mbit/s Leitung.
Aus dem Router kommen aber gerade mal 100 Mbit/s (LAN)
Wo kann ich den Wert für den Max. ausgang anpassen, so das auch 200 Mbit/s rauskommen?
Folgender Router verwende ich R6300v2.
Danke für eure Hilfe
Message 1 of 4
Retired_Member
Not applicable
Re: Geschwindigkeit R6300V2
I'm responding in white font.
I would factory default it  then reload Firmware.
Message 2 of 4
James08
Hello
I have already made a reset, which has brought nothing.
Someone told that the rate to be distributed to all Port's.
But I only need one, but there should be full speed.
Message 3 of 4
DexterJB
NETGEAR Moderator
Hi @James08,
1. Does the issue happen on both wired and wireless devices?
2. What is the firmware version of the router?
3. Have you tried re-flashing the firmware?
Dexter
Community Team
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2298 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
