Reply
Help tracking down why my WIRED connection is SLOW
fxtech
I just got the 3700 to replace a 3500, hoping it would fix the problem, it hasn't. The router is connected to an ActionTec DSL modem.
My WIRELESS Mac gets great speeds - about 1.3MB/s (my DSL connection is 1.5Mb/768Kb). If I try to download the same file from my PC, which is connected over GigE to the router, I get about .25Mb, consistently.
I don't think it's the router, since my PC used to be pretty fast. I'm hoping someone can give me some tips for tracking down why my PC is "slow". Specs are Windows 7 x64, 8GB, 2.6Gz Quad core, firewall is enabled (still slow if disabled), no trojans that I can find, etc. It's really odd. I can't even stream 720P YouTube videos on the PC without constant stalling, but they play fine on my Mac.
Aside from wiping my PC, is there a checklist or anything?
Message 1 of 31
Retired_Member
Not applicable
Re: Help tracking down why my WIRED connection is SLOW
I've had a few issues with certain devices not wanting to auto-negotiate correctly on this router. Try hard setting speed and duplex and see what that does.
One way you could verify a speed/duplex mismatch is with the ping command. You would see packet loss (which would be the cause of your "slowness").
Message 2 of 31
fxtech
I just removed the router and plugged the PC directly into the modem and now I'm getting great speed - full 1080P streaming from Youtube, etc.
My ping times to google.com are 63ms, both through the router and straight to the modem.
So maybe it IS something going on with this (and the 3500) router. Since it USED to be fast, could my ISP have changed something to affect Windows 7 performance? Or maybe a recent OS update?
When you said to fiddle with duplex settings, where would I do that? I have an NVIDIA nForce networking controller.
Message 3 of 31
fxtech
BTW, here is my ipconfig on the Windows box (attached).
Windows IP Configuration
Host Name . . . . . . . . . . . . : andor
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : NVIDIA nForce Networking Controller
Physical Address. . . . . . . . . : 00-1B-FC-8D-00-B7
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::f574:c6a9:8099:e5f2%11(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.6(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Thursday, October 21, 2010 10:27:53 AM
Lease Expires . . . . . . . . . . : Friday, October 22, 2010 10:50:31 AM
Default Gateway . . . . . . . . . : XX.XX.XX.XX (ISP Gateway)
192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 234888188
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-12-AF-61-07-00-1B-FC-8D-00-B7
DNS Servers . . . . . . . . . . . : 216.146.35.35
216.146.36.36
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter VMware Network Adapter VMnet1:
Description . . . . . . . . . . . : VMware Virtual Ethernet Adapter for VMnet1
Physical Address. . . . . . . . . : 00-50-56-C0-00-01
DHCP Enabled. . . . . . . . . . . : No
Link-local IPv6 Address . . . . . : fe80::f934:20eb:9dd4:b825%14(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.154.1(Preferred)
DHCPv6 IAID . . . . . . . . . . . : 318787670
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Ethernet adapter VMware Network Adapter VMnet8:
Description . . . . . . . . . . . : VMware Virtual Ethernet Adapter for VMnet8
Physical Address. . . . . . . . . : 00-50-56-C0-00-08
Link-local IPv6 Address . . . . . : fe80::51a4:22ed:75d1:a88b%16(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.239.1(Preferred)
DHCPv6 IAID . . . . . . . . . . . : 352342102
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Tunnel adapter isatap.{5036ADD9-9C65-4774-B805-247B68A13ED0}:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Tunnel adapter Local Area Connection* 9:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Tunnel adapter isatap.{62224ED4-8B80-4961-84E0-79A8C2781170}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter isatap.{4710D772-DEBC-4233-B4E4-06C375B8236A}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
Message 4 of 31
fxtech
Anyone?
My feeling is this is some strange interaction between Windows 7 and/or my particular NIC and the router (if I take the router out of the equation all is fine).
Should I be contacting official Netgear support channels?
Message 5 of 31
NatRay
Tutor
Take a hard look at the router's configuration. Is the router using the ISP's DNS servers? Is the router configured as a DHCP server? Are your clients hard wired or wireless? If wireless, are you using the router's Access List via MAC address? Have you setup Reserved IP's using the correct MAC address?
These are just a few of the configuration issues that could affect your computer's performance. Taka a really hard look at DNS . . .
Best regards,
Nat Ray MCSE/MCT since 1997
_______________________
Cox Communications > SB6120 DOCSIS 3.0 > WNDR3700v1 (4), WNDR3400v2 (2), WPN824v2 (2), R7000, RT-N66R *AP(s) via Wired Backbone* > Ooma Telo / D-Link DGS-1024D > NeoTV-550 (3) . . .** HPEnvy800 -PHX **
DD-WRT v24-SP2 (12/14/11) std. Build 18007
Optimize your network: Disable IPv6 . . . Post responsibly . . .
‘Quality trumps Quantity’
Message 6 of 31
fxtech
I doubt it's DNS, since my timing tests were done on single large files, and wouldn't require multiple DNS lookups. And my wireless Mac doesn't have any performance issues at all going through the same router. Also, I'm getting over 1MB/sec from a Linux server also connected through the router.
It's something related to this Windows 7 machine and the router.
Message 7 of 31
fxtech
Turned off UPnP and now the Windows machine is much faster. Gonna look into this more.
Message 8 of 31
NatRay
Tutor
Have you tried the physical connections? i.e. bad cable, port, or interface . . .
Best regards,
Message 9 of 31
fxtech
Cable/port: plugged my Mac into the same cable = no problem
Interface: plugged directly into Modem = full speed
Message 10 of 31
NatRay
Tutor
With that said . . . The fly in the ointment is the router . . . Smiley Sad
Silly question . . . we are all entitled to one per year: Do you have another router to test the connection?
Best regards,
Message 11 of 31
fxtech
Yeah, I had a Netgear 3500 the week before that (still have it), that had been working fine. The "problem" only manifested within the last 2-3 weeks. But the problem started, and thinking it was the router going, I got the 3700. And was surprised to experience the exact same problem.
So a couple of hours ago I go through all the router settings carefully. I see UPnP is turned on and my Windows machine is in the list below it. I turned off UPnP and immediately tried downloading a large file (a Linux ISO). I got over 1MB/sec! Then I tried one of those 1080P YouTube videos and it streamed perfectly.
Now, a few hours later, everything is slow again. I just tried a 1080P Youtube video and again it stalled and will not stream. Same thing plays perfectly on my wireless MacBook sitting right next to it. :-(
This is very frustrating!
Message 12 of 31
NatRay
Tutor
192.168.1.1
216.146.36.36
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
I have taken a closer look at your IP Configuration and count no less than 3 class C networks (192.168.1.6, 192.168.154.1, 192.168.239.1). In order for your box to function properly routes must be setup via the NVIDIA adapter. Has this been done?
Routes are setup via the 'Advanced . . .' settings of the Internet Protocol Version 4 (TCP/IPv4) Properties sheet. I am not familiar with the MAC nor VMware, but I suspect your machine is configured as a router with a corrupt routing table . . .
If this is the case you will need a crash course in routing or disable/remove the VMware adapters . . .
Best regards,
Message 13 of 31
fxtech
Those were inactive VMWare virtual adapters. Just to check I uninstalled VMWare which also removed those adapters. Now I have just the 192.168.1.6 network. The problem remains.
Message 14 of 31
NatRay
Tutor
We aren't giving up yet . . . From the router: Are there any log entries related to the assigned DHCP address, or the NVIDIA's MAC address? If so, what are they?
Best regards,
Message 15 of 31
NatRay
Tutor
Have you checked the Link Speed and Duplex of your Local Area Connection's NIC (Network Interface Card)?
The default setting is 'Auto Detect' . . . set it to the fastest Link Speed your NIC can support, and Full Duplex: i.e. 100Mbps/Full Duplex -or- 1000Mbps/Full Duplex . . .
Navigate to:
Control Panel\Network and Internet\Network Connections . . .
Select you Local Area Conection by using the left mouse button . . . use the right mouse button to select 'Properties' . . . Click on the 'Configure' button . . . Select the 'Advance' tab . . . in the list of properties select 'Link Speed & Duplex' . . . use the drop down button to select the desired 'Value' . . .
You probably won't have to reboot, however, its always a good policy to reboot after a configuration change to ensure the change is written to the registry . . .
Best regards,
Message 16 of 31
NatRay
Tutor
Naturally, the above information is contingent upon all components of your network operating at the speed selected. i.e. The WNDR3700, with proper cabling, can support up to 1000Mbps. However, if your laptop's NIC supports Gb transmissions, but it's connected via a switch that maxes out at 100Mbps you are limited to what the switch can handle. This is refered to as a 'bottleneck'.
In this case you would choose 100Mbps/Full Duplex . . .
Best regards,
Message 17 of 31
NatRay
Tutor
Hard setting the Link Speed and Duplex was suggested by htismage in an earlier post, but I didn't see a response . . . This forum needs an 'Edit' button . . . Smiley Sad
Best regards,
Message 18 of 31
bimbobo
..the WNDR3700 seems picky about "ethernet cable".
Try a CAT5E or CAT6..
CAT6 solved a gigabit "issues" for me.., you never know.
Regards
Netgear NDA Betatester
Message 19 of 31
jlewter
Guide
Give us a "Route Print" please.
Also, I dont get why your blanking out this bit
192.168.1.1
You shouldnt have two gateways listed... Only the router..
If the incorrect gateway is listed then packets are going to get lost or delayed while searching for a path.
Message 20 of 31
NatRay
Tutor
Nice catch jlewter . . . I missed that one . . . Smiley Surprised
Best regards,
Message 21 of 31
fxtech
There are several of these:
[DHCP IP: 192.168.1.6] to MAC address 00:1b:fc:8d:00:b7, Monday, October 25,2010 06:12:39
For that IP address, looks like there is one every 10-15 minutes or so. Normal?
Message 22 of 31
fxtech
I X'd out the ISP-assigned IP address. Didn't think it was relevant.
Interface List
11...00 1b fc 8d 00 b7 ......NVIDIA nForce Networking Controller
1...........................Software Loopback Interface 1
12...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter
13...00 00 00 00 00 00 00 e0 Teredo Tunneling Pseudo-Interface
IPv4 Route Table
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 192.168.1.1 192.168.1.6 10
127.0.0.0 255.0.0.0 On-link 127.0.0.1 306
127.0.0.1 255.255.255.255 On-link 127.0.0.1 306
127.255.255.255 255.255.255.255 On-link 127.0.0.1 306
192.168.1.0 255.255.255.0 On-link 192.168.1.6 266
192.168.1.6 255.255.255.255 On-link 192.168.1.6 266
192.168.1.255 255.255.255.255 On-link 192.168.1.6 266
224.0.0.0 240.0.0.0 On-link 127.0.0.1 306
224.0.0.0 240.0.0.0 On-link 192.168.1.6 266
255.255.255.255 255.255.255.255 On-link 127.0.0.1 306
255.255.255.255 255.255.255.255 On-link 192.168.1.6 266
Persistent Routes:
None
IPv6 Route Table
Active Routes:
If Metric Network Destination Gateway
13 58 ::/0 On-link
1 306 ::1/128 On-link
13 58 2001::/32 On-link
13 306 2001:0:4137:9e76:3c90:7ed:3f57:fef9/128
On-link
11 266 fe80::/64 On-link
13 306 fe80::/64 On-link
13 306 fe80::3c90:7ed:3f57:fef9/128
On-link
11 266 fe80::f574:c6a9:8099:e5f2/128
On-link
1 306 ff00::/8 On-link
13 306 ff00::/8 On-link
11 266 ff00::/8 On-link
Persistent Routes:
None
Message 23 of 31
fxtech
Navigate to:
The control panel shows the NIC connected at 1.0Gbps, and it is going through a Netgear 16 port GigE switch. Though I've had the same issue with the computer going directly to the GigE ports on the router itself.
Do you think changing it to 100Mbps Full Duplex would make any difference if it's already connected at 1.0 Gps? Also note all is fine when the computer is plugged directly into the modem (bypassing the router).
Message 24 of 31
jlewter
Guide
the routing tables look fine (all of your other adapters have been removed...)
What is the "Location" Set to under windows...
It shouldnt make a hoot when it comes to internet browsing.
I think "Location" is based off of the MAC your connecting to, and some firewall rules may apply based on the device it detects.. So it will treat your modem and router differently. All of the IPv4 adapter settings are global for the wired device me thinks.
And when you do a "ipconfig /viewall" is it still listing 2 gateways?..
If it is then I would reset the ipv4 settings fully by going into a command prompt and typing
"netsh int ip reset resetlog.txt"
then rebooting the pc..
using the netsh command may fix the problem anyhow so you could give it a go.
Message 25 of 31
Discussion stats
  • 30 replies
  • 13602 views
  • 0 kudos
  • 7 in conversation
Announcements
