Reply
How do I enable a QoS setup in a Netgear WNR614 router?
mdka
Follower
there is no option for enabling Qos setup in Netgear WNR614 router. i searched whole router settings to limit my internet speed.
Message 1 of 2
ElaineM
NETGEAR Employee Retired
Re: How do I enable a QoS setup in a Netgear WNR614 router?
Welcome to the community, @mdka
The unit does not have a QoS feature.
What are your requirements?
If you want to prioritize the the internet traffic then you may want to get a router that has QoS feature.
However, if you're talking about limiting the internet usage due to data cap limit set by your ISP, you may check out traffic meter.
Both of these features are not supported by your router. You will need to update your device to a newer one in order to have these features.
Check this link for list of routers and specs.
ElaineM
NETGEAR Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2797 views
  • 0 kudos
  • 2 in conversation
Announcements
