Reply
How to access 192.168.1.1
davidmadem
I can not login to 192.168.l.2 what would be the reason?  I can not go in there now. How do I log in to 192.168.10.1?
Model: JNDR3000|N600 Wireless Router
Message 1 of 9
William10a
Master
Re: How to access 192.168.1.1
192.168.1.1 is the normal ip address of most routers made today  192.168.1.2 would be any device connected to the network 192.168.10.1 would be the same story as 192.168.1.2 .
How are you trying to log into the router 192.168.1.1 would via wired lan cable and the programed ssid and password that is on a white sticker on the router would have to be used to log in via wifi ?
The model number of the router would possible help.
Message 2 of 9
Some times it may be due to Cache or cookies. Try to clear you cache and then access 192.168.1.1 login page.
With Regards, Andrew K Hinkle
Message 3 of 9
Follow these Simple Steps for 192.168.1.1 Login through the Gateway which gives access to Configure and Change Settings of your WiFi Router.
  • Enter Official Site  192.168.1.1 in any of your Browser (IE, Firefox, Google Chrome, Safari).
  • If the Login Page is Not Opening, then 19216811 is not your Router’s Default IP Address. Refer this Article to Find Default Router IP Address.
  • Once you Found the Correct IP Address, Insert the same into your Web Browser Address Bar.
  • You’ll be Forwarded to Login Panel which asks for Username and Password to Sign In. Check out Default Username and Password.
  • Follow this Guide if you Forgot Username and Password of your Router.
  • Put down the Credentials and you’re in.
Message 4 of 9
JackDd
I am currenty unable to login to my R9000 Nighthawk. I am connected directly with a network cable. I get the connection but see a 401 code. No where to put admin credentials.
I no longer have the original PC that I set up the router with, so I am trying to connect with my Macbook Pro.
I am assuming with the original PC I may need to reset the router and start over. Or, would I be able to connect a different PC?
TIA!
Message 5 of 9
antinode
Guru
   First, start your own, new thread, for your own, different problem,
and let this old, dead thread rest in peace.
   Firmware version?
   "unable" is not a useful problem description.  It does not say what
you did.  It does not say what happened when you did it.  As usual,
showing actual actions with their actual results (error messages, LED
indicators, ...) can be more helpful than vague descriptions or
interpretations.
> [...] I get the connection but see a 401 code. No where to put admin
> credentials.
   When you do what, exactly?  Web browser?  URL?
Using a Mac (or any different computer) should not cause any
particular trouble.
   A settings reset might solve some odd-ball problems, but not using
some particular computer is unlikely to be your actual problem.
   Visit https://www.netgear.com/support/ , put in your model number, and look
for Documentation.  Get the User Manual.  Look for "Factory Settings"
(or "reset").
Message 6 of 9
richardgroover
Thanks
-Richard Groover
Message 7 of 9
richardgroover
Message 8 of 9
_emmadavis
Some times it may be due to Cache or cookies. Try to clear you cache and then access the login page.
And for any further issues regarding jiofi login do visist the site!
Message 9 of 9
Discussion stats
  • 8 replies
  • 114382 views
  • 0 kudos
  • 7 in conversation
Announcements
Orbi WiFi 6E
