Rajendra_Prasad's avatar
Apr 09, 2022
How to enable / setup wisp operation mode for netgear router for model wnr614
Hi All,
I would like to know how to enable / setup wisp operation mode for netgear router for model wnr614, such that i can extend wifi range within home.
Kindly assist.
Best Wishes,
Rajendra
1 Reply
  • michaelkenward's avatar
    michaelkenward
    The term "wisp operation mode" isn't something that crops up here much:
    Search - NETGEAR Communities – wisp
    What is a WISP Mode on a Wireless Router • Wi-Fi Settings
    From your description it sounds like you want to use the wnr614 in repeater or "bridge" mode.
    Manuals are always a good place to start.
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    For clues, check the section in the manual Wireless Distribution System
    Not all routers support this sort of operation.
    The wnr614 is an aged (~2014), downmarket router with dated wireless technology. Don't expect much.
