Reply
How to login into Netgear R8000 Nighthawk Tri-Band ?
Sertps23
Luminary
I want login to my router admin settings. basically I am planning to to bridge my 2 rouuters so I nedd to access the admin setting sof my router. I am facing problem when trying to access Netgear Nighthawk R8000. What is the login url for this device ?
Message 1 of 2
schumaku
Guru
Re: How to login into Netgear R8000 Nighthawk Tri-Band ?
Once a router is operating as a bridge or wireless access point, it will no longer be reachable by using the handy http://routerlogin.net/ or the like. You have to figure out which IP address is assigned by the DHCP server (typically on the primary router) and use http://192.168.1.whatever/
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2467 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
