Reply
* How to use a 4500 as an AP to the 6300 *
Digitalborg
Greetings All.
I have a 4500 which I want to use ONLY as access point. I have a 6300 as my main household router.
I have set the following options on the 4500:
* Turned on AP.
* Enabled Bridge Mode
* Turned off DHCP (so no conflict on network with two (2) DHCP Server)
However, anytime a client tries to connect it cannot. I need a printer and one (1) machine to connect.
Any advice or a starting point would be appreciated.
Thank you.
:confused:
P.S. Do you need two (2) 6300's for this to work correctly?
Message 1 of 5
jmizoguchi
Virtuoso
Re: * How to use a 4500 as an AP to the 6300 *
http://kb.netgear.com/app/answers/detail/a_id/20927
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 5
Digitalborg
Thank you.
However, the wireless network part of the network on the 4500 is not working correctly (no ip addresses being issued). Is there something else I need to configure for wireless?
Thanks.
:confused:
Message 3 of 5
Digitalborg
Thank you.
However, clients cannot connect to the wireless network from the 4500. IP addresses are not being issued.
Is there another configuration setting I need set?
Thanks.
Message 4 of 5
jmizoguchi
Virtuoso
Should not. Test out with static ip on wifi device and see if that work to rule out dhcp issues
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 5 of 5
Discussion stats
  • 4 replies
  • 3510 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
