Reply
I am trying to decide between two Netgear routers.
enichante
Follower
Costco has the NETGEAR Nighthawk 6-Stream AX4300 for $130, down from $200 right now.
It says it's wifi six but the details show up to 802.11 ac
Is this some sort of strange advertising issue?
I'm looking at another similar wifi router from the same line that's newer and more expensive.
Netgear Nighthawk AX4200, which appears to be a true wifi 6 router with 802.11ax.
Message 1 of 4
Guru
Re: I am trying to decide between two Netgear routers.
Are you referring to this model router?
https://www.netgear.com/support/product/rax45.aspx
It supports AX modes, along with older wifi modes like AC and N.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode |  Wifi Router RBK953 (Router Mode) 2.5Gb Wired Backhaul | Switches NG GS105/8, GS308v3, GS110MX and XS505M | XR1000 (Router Mode) and RBK853 AP Mode  |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
Message 2 of 4
DNB09876
DNB= do not buy this crap. 2 years old, and they are done with you…after the first 6 months of purchase. They give you no customer service they give you no ways to fix things they just cut you off. Just saying messages will be after learning the hard way do not buy their crap!
Model: AC2100|Nighthawk AC2100 Smart WiFi Router
Message 3 of 4
Guru
Other router mfrs have similar warranty policies.
Message 4 of 4
Discussion stats
  • 3 replies
  • 477 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
