Reply
I can't get on to my wireless devices when my pc is on
mlipp54
Follower
My router works fine but only when my pc is not on. The ethernet cable is hooked into the pc...how can I get wireless devices to work when my pc is on?
Message 1 of 2
ElaineM
NETGEAR Employee Retired
Re: I can't get on to my wireless devices when my pc is on
Welcome to the community, @mlipp54
What's the exact model number and version of your router?
The router should allow Internet connection whether your PC is on or not.
It's possible that your router needs reconfiguration that's why it won't allow simultaneous Internet access.
I suggest that you reset the router to its factory default settings then reconfigure it after.
You may select the appropriate steps below on how to reconfigure the router.
Cable Connection
DSL Connection
Let us know what happens.
ElaineM
NETGEAR Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1661 views
  • 0 kudos
  • 2 in conversation
Announcements
