- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
I have an R6400 and want to connect a HDD via USB as a NAS drive
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a Nighthawk R6400 router and have a HDD connected to it via its USB port. I want to set up Readycloud but cannot seem to do it. Advice please?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: I have an R6400 and want to connect a HDD via USB as a NAS drive
Hello, Mph3842,
What seems to be the error when setting it up?
https://www.netgear.com/support/product/r6400.aspx#docs
Check the link out there should be a manual for the readycloud setup.
Rhys
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for your reply. When I look at the Netgear Router page, under Readyshare, the Readycloud button does not appear (see photo). The USB drive I have connected is an 8TB Seagate Hub Plus.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Readyshare is very picky about the USB drives it will accept. 8TB is too big for most devices. The limit seems to be about 4TB.
This list will give you some clues, although it is far from comprehensive:
ReadySHARE USB Drives Compatibility List | Answer | NETGEAR Support
Your subject says "want to connect a HDD via USB as a NAS drive". By convention NAS usually means Ethernet. That's not USB.
- Mark as New
- Bookmark
- Subscribe
- Permalink
> I have a Nighthawk R6400 router [...]
R6400[v1] or R6400v2? Look for "Model" on the product label.
Firmware version?
> [...] When I look at the Netgear Router page, under Readyshare, the
> Readycloud button does not appear (see photo). [...]
I don't trust Netgear router firmware with my stored data, so I don't
use this stuff, so I don't pay close attention, but I got the impression
from my readings here that Netgear was dropping (had dropped?)
ReadyCLOUD support from recent firmware versions on some (all?) its
routers. This could be an artifact of my usual false-memory syndrome,
but, if you loaded an older firmware version and the feature reappeared,
then that would be suggestive. I'm too lazy to scan all the firmware
release notes to see if anything relevant could be found that way.
> [...] By convention NAS usually means Ethernet. That's not USB.
Sigh. "By convention", in this context, NAS means Network-Attached
Storage.
https://en.wikipedia.org/wiki/Network-attached_storage
A purpose-built NAS server typically uses a high-speed interface
(Fibre Channel, SCSI, SAS, SATA, ...) to communicate with its storage
devices (disks, et al.), and an Ethernet or other network interface to
communicate with its client devices.
Some router models offer some NAS capability using a USB interface to
a storage device, and the usual Ethernet interface for communication
with a client. That is what's being discussed here.
Some of the participants in these forums seem to believe (and enjoy
telling others) that "NAS" means a box whose label says "NAS", rather
than a gizmo which attaches a storage device to a network.
Others believe that any gizmo which attaches a storage device, even a
USB-connected storage device, to a network, like, say, a Netgear
R6400[vX], constitutes network-attached storage (NAS). I have no
trouble with this functional definition (because I can read), but some
people seem to, which leads to "help" like:
A USB-connected disk, by itself, is not (normally) NAS. A
USB-connected disk, when connected to a computer with the right
programming (and a network interface), can be, literally, exactly,
network-attached storage.
But I don't expect to persuade the local "experts".
It's true that a purpose-built NAS server which does not use USB as
its storage interface will typically have faster hardware, and
software/firmware which is more reliable and has more features (like
RAID, for example) than a consumer-grade Netgear router-as-NAS. But,
network-attached storage is still network-attached storage. For some of
us, at least.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for your response. I agree with you that a USB attached drive is NOT the same as an NAS drive. All I want to do is to be able to upload my photos from my phone to the USB drive since Gogle Photos is now limiting space. If you can suggest a way for me to do that I would be appreciative. The upload need not be automatic as I do not mind uploading them once a week by myself but what I do want to do it to be able to uload them (or view them) from anywhere. Thanks in advance.
M
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] All I want to do is to be able to upload my photos from my phone
> to the USB drive since Gogle Photos is now limiting space. [...]
You seem to want plain-old ReadySHARE (LAN access to the shared
storage), not ReadyCLOUD (outside-world access to the shared storage).
If your actual complaint is that the "8TB Seagate Hub Plus" is not
appearing under "Available Network Folders", then that's not a
ReadyCLOUD problem.
> [...] what I do want to do it to be able to uload them (or view them)
> from anywhere. [...]
So, "All" was not really "all"?
_That_ would be a ReadyCLOUD problem. If that feature's not in the
current firmware, then I'd investigate older/different firmware.
> Firmware version?
Still wondering.
To deal with the empty list of "Available Network Folders"...
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual. Read. Look for "USB
Storage Device Requirements". Find the list of supported file system
types. Note that exFAT is not among them.
What is the file system on your "8TB Seagate Hub Plus"? If it's not
one of the supported file systems, then you might want to format it
appropriately. (NTFS is popular.)
> too big for most devices. [...]
I'd try it with a supported file system before abandoning all hope of
using the whole thing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Congratulations. You have made the right first decision. Too many people leave important photos on their phones and then wonder why they all disappear when they lose their phones.
The best strategy probably depends on the phone. I use cameras rather than phones, but the same thing works. I can set up the cameras to copy photos over wifi, but I find that it is better just to use a USB link to a PC and then copy everything from there.
But that raises the first question, you have a USB drive attached to the R6400. Is there also a PC in there?
If so, I would be tempted simply to copy the photos from the phone to the USB drive using the PC as an intermediary.
I also use ReadySHARE to copy the photos on to a USB drive. (I like to have more than one copy.) I even use ReadyCLOUD to get at them.
Despite recent claims from Netgear that it is killing the service, ReadyCLOUD still works. I have more than 20 years of photos on a 2TB USB drive.
I can't see that I will ever get 8TB of storage for photos. If you look at the USB compatibility page I linked to earlier, you will see that there are plenty of 4TB drives that work with the R6400. Get one of those and it should work fine with ReadySHARE and ReadyCLOUD.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am seeking a home grown solution to replace Google photos without the expense of a synology NAS set up. I will try a smaller USB drive. Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] I will try a smaller USB drive. [...]
Do you expect that to restore a ReadyCLOUD control to the BASIC >
ReadySHARE page in your router's management web site? I don't.
I'd expect the results from a smaller drive with an incompatible file
system to be very similar to the results from a larger drive with an
incompatible file system.
Of course, with my weak psychic powers, I don't know which file
system is on your "an 8TB Seagate Hub Plus", but one of us might be able
to find out by connecting it to some computer or other. It's possible
that 8TB is too big for your router firmware, but that's not the only
possible problem.
Is "an 8TB Seagate Hub Plus" anything like an "8TB Seagate Backup
Plus Hub"?
- Mark as New
- Bookmark
- Subscribe
- Permalink
A smaller drive would be a good start. As you will see from the compatibility list for the R6400 , there are plenty of 4TB drives there, but nothing bigger.
That's been common knowledge for some years now, as you will see from many similar conversations here.
There are one or two claims from Netgear that some devices will take bigger drives. For example, the R7000 and R7000P are said to accept the Seagate Backup Plus Hub 8TB SRD0PV1. (If someone gives me one of those drives, I might be tempted to try it on my R7000P.) But that may depend on having the righht firmware.
Fortunately, USB support extends to most of the file systems that you are likely to encounter. (Check the list in the manual.) Trouble arises when you want to use a USB drive that needs its own software to work.
You could experiment with ReadyCLOUD and any USB drive that you have lying around before you buy a new drive, just to see that this bit still works. Netgear has a habit of changing things on new firmware, although it seems to reserve those tricks for workhorse routers like the R7000 and R7000P. It has removed various features from those to make way for services like Circle and Armor that it can sell to owners.
But even when Netgear says that it has ditched something you can't be sure. For example, on recent firmware update warned of the death of ReadySHARE Vault on the R7800. Nope. Still works here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
> are likely to encounter. [...]
Unfortunately, it does not extend to one of the file systems which
you are most likely to encounter, namely, exFAT.
It's not obvious to me that "most of the file systems that you are
likely to encounter" is a useful concept.
> You could experiment with ReadyCLOUD [...]
How, exactly, if the router's management web site lacks any such
option?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] My drive does not have es Fat.
> What is the file system on your "8TB Seagate Hub Plus"? [...]
Just one of the many unanswered questions already asked. Look for
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Mph3842 wrote:
Thank you. My drive does not have es Fat.
I wouldn't expect it too. Out of the box, USB drives I have bought recently come "Formatted NTFS for Windows" with a warning "Requires reformatting for macOS". No need to change anything, especially given your intended use of the thing as a photo store.
One thing that hasn't come up before is the router's role as a media server. This could be useful if you want to view photos on something like an Xbox or Playstation. This involves ReadyDLNA, which is just the sort of feature that Netgear has been killing with its firmware "improvements". Fortunately, the R6400 seems to have escaped ths fate and your router should support ReadyDLNA along with ReadyCLOUD.
Which NETGEAR routers support ReadyCLOUD? | Answer | NETGEAR Support
As I suggested earlier, there is nothing to stop you from playing with these features before you go the whole hog.
Attach a USB drive to ReadySHARE in the router, begin the journey here:
Sign up and sniff around in there and you will find the client you need. (Some of the links wired into the manuals no longer work.)
I use ReadyCLOUD on a daily basis. I also have the Android app for it.
