Reply
I have to reboot my WNR2000V4 daily
amit2546
I have Neatgear WNR2000V4 router, it has Router Firmware Version V1.0.0.60. I have restart my router daily, It log out all the devices from wifi conection and when i tried to wnter in wifi network, it asks me password and when i enter my wifi password, it denies to get connection, some times i have wifi connection and when i try to coneect to me on 192.168.1.1 it does not show tha page so i have to reboot my router daily, i am realy annoyed with this problem.
Message 1 of 8
ElaineM
NETGEAR Employee Retired
Re: I have to reboot my WNR2000V4 daily
Welcome to the community, @amit2546
I apologize for the inconvenience this has caused you.
Have you tried resetting the router? Try to reset the router using a paperclip for 20 seconds.
After reset, you will need to reconfigure the router to get the Internet connection back and input all the settings you were using.
Let us know what happens.
ElaineM
NETGEAR Community Team
Message 2 of 8
amit2546
I have done this, reset my router many times, but the the p oblem ia as it Is. It doesn't change.
Message 3 of 8
amit2546
Does this happened because of my router running continuously,?
Message 4 of 8
amit2546
I am also having the problem when internet is not working, it shows green light instead of yellow light, but when I purchased this when the internet is not working yellow light is showing instead of green light. Does this problem happened because it f router firmware up gradations?
Message 5 of 8
ElaineM
Firmware upgrade fixes bugs and it improves the products quality.
Anyhow, it's possible that the router is starting to degrade itself that's why it's showing these symptoms.
Since you have reset the router, try to reflash the firmware one more time and see if it will help.
Reload the latest firmware and make sure that you upgrade the firmware using a hardwired pc.
This is to ensure that the firmware will be loaded correctly without any interruption.
Once done, configure the router to get it up and running.
ElaineM
Message 6 of 8
amit2546
I have done this but it doesn't help in my router conditions.
Message 7 of 8
ElaineM
Who is your ISP?
Is it Cable or DSL connection?
How did you configure the settings?
Will you still get an IP address from the router?
Are you configuring it hardwired?
Can you verify if you have tried these steps.
ElaineM
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 2516 views
  • 0 kudos
  • 2 in conversation
Announcements
