Discussion stats
  • 3 replies
  • 2648 views
  • 0 kudos
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
I lost 5G compoment with Router AC1750 Dual Band Gigabit (R6300v2)
When I initially installed this dual-band router I had both networks available: 2.4G and 5 G. Now there is only one. 5G is gone. What could be the reason and/or the remedy?
Model: R6300v2|AC1750 Dual Band Gigabit router
Message 1 of 4
Highlighted
Re: I lost 5G compoment with Router AC1750 Dual Band Gigabit (R6300v2)
Is it turned on?
Is it broadcasting the SSID?
Can the devices you are trying to connect work with 5G?
Read about that stuff in the manual:
R6300v2 | Product | Support | NETGEAR
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 4
Highlighted
This could the range issue. My android sees 5G. My desktop, that used to have a medium strength signal doesnt see it at all any amore. I have noticed that with temperature and humidity fluctuating the range of my Wi-Fi changes too. Blootooth devices are affected in particular. I'll keep an eye on it. And thanks so much for being there to help out. Michael
Message 3 of 4
Highlighted
5G may be faster than 2.4 GHz, but it certainly has a shorter range.
Guess that's why most wifi devices come with both. Removing 2.4 would be suicide.
Just another user.
Message 4 of 4
