Reply
I need help with my recovering my password.
Jeanne2361
Follower
I need help recovering my password. Canceled my cable but kept the internet. Bought a firestick but need my internet password. How do I go about finding it out? Thanks
Message 1 of 3
Guru
Re: I need help with my recovering my password.
You're missing your wifi password or router password?
If its your wifi password you can go to routerlogin.net and log into the router to get those.
default login is admin  and default password is password.
If you've changed the login password and have forgotten it you can hit cancel when it asks for password and it'll take you to where you put in your serial number and then answer the security questions you would have setup.  If you've forgotten those, then you need to reset the device back to factory and start over.
CM2000-> RAXE500-> GS716v2-> WAX218-> EX8000
Message 2 of 3
I assume that this means that you cancelled cable TV rather than cable internet.
If you mean the password that you use to login to the internet, then ask the Internet service provider.
Otherwise, follow what @plemans says.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 331 views
  • 0 kudos
  • 3 in conversation
Announcements
