Reply
I need of help with my DL/UL Speeds
JRojas25
Novice
I am in serious need of help. I have no clue about routers! Let me explain my situation. We had a terrible lightning storm on Sunday and had several strikes damage some items including our router and modem. We had our ISP come out on Monday and they checked our modem (it was bad) so they gave us a new one and checked our connections.
I purchased a very inexpensive router and it was terrible, so I returned it and purchased the WNDR3700 V3. The connection is slightly better, but the download and upload speeds are terrible. We had a very old router and our speeds were fantastic, so not sure what is going on.
I live in the 2 story town home. The router/modem are downstairs and the computers are in the room directly upstairs. *Same setup we used to have*
We called ISP and they had us check the modem speeds and everything was fine.
I e-mailed Netgear and there suggestion was to change the MTU. I tried 1492, 1400, 1358, and 1300. Some were slightly better than others.
I then called Netgear. Here is what they had me do.
First, he had me go to advanced wireless settings and change the fragmentation lengths on both the 2.4GHz and 5GHz to 2305 and the CTR/RTS values on both to 2306.
When the speed was worse he told me to update the firmware and call back. I purchased the router yesterday and it updated itself.
I called back and received another tech person that had me change to channel 11 and said to wait a few days. She said that as long as I can open webpage that it is working. I find this ridiculous!!!! I am not just looking to open up a web page.
We use the wireless to connect 2 IMacs, 2 iPhones, PS3, Wii, and an Apple TV.
I ran a speed test on testmy.net and here is what I got (this is with the computer plugged into the router downstairs as advised by tech support):
:::.. Download Test Results ..:::
Download Connection:: 363 Kbps or 0.4 Mbps
Download Test Size:: 256 kB or 256 kB or 262144 bytes
Download Speed:: 45 kB/s
Tested At:: http://TestMy.net version:12
Validation Link:: http://testmy.net/db/6gtdDG1
Test Time:: 2012-06-15 12:39:03 Local Time
1MB Download in 22.76 Seconds - 1GB Download in ~6 Hours - 6X faster than 56K
This test of exactly 256 kB took 5.636 seconds to complete
Running at 3% of hosts average (Road Runner)
User Agent:: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_7_3) Apple
:::.. Upload Test Results ..:::
Upload Connection:: 884 Kbps or 0.9 Mbps
Upload Test Size:: 579 kB or 579 kB or 592920 bytes
Upload Speed:: 111 kB/s
Validation Link:: http://testmy.net/db/0c4OpxB
Test Time:: 2012-06-15 12:40:20 Local Time
1MB Upload in 9.23 Seconds - 1GB Upload in ~3 Hours - 16X faster than 56K
This test of exactly 579 kB took 5.241 seconds to complete
Running at 60% of hosts average (Road Runner)
Please help me if you can!
Message 1 of 11
readysecure1985
Re: I need of help with my DL/UL Speeds
What speeds are you getting when connected directly to the modem? If you turn off the wireless and ensure that only this one computer is using the router do your speed tests change? Since a lightning strike started all of this and your ISP replaced the modem, did they check the outside wiring for lightning damage also? Have you tried any other speed test sites?
Message 2 of 11
JRojas25
Novice
I removed the wireless and plugged it directly into the modem.
On Bright House Speed Test (my ISP) it reads:
9.63 Mbps for DL and 0.97 Mbps for UL.
Results from testmy.net:
Download Connection:: 9772 Kbps or 9.5 Mbps
Download Test Size:: 8.2 MB or 8441 kB or 8643467 bytes
Download Speed:: 1222 kB/s or 1.2 MB/s
Validation Link:: http://testmy.net/db/geYn5Mf
Test Time:: 2012-06-15 13:36:20 Local Time
1MB Download in 0.84 Seconds - 1GB Download in ~14 Minutes - 175X faster than 56K
This test of exactly 8441 kB took 6.91 seconds to complete
Running at 82% of hosts average (Bright House Networks)
User Agent:: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_7_3) AppleWebKit/534.55.3 (KHTML, like Gecko) Version/5.1.5 Safari/534.55.3 [!]
Upload Connection:: 894 Kbps or 0.9 Mbps
Upload Speed:: 112 kB/s
Validation Link:: http://testmy.net/db/JrOvB2i
Test Time:: 2012-06-15 13:37:51 Local Time
1MB Upload in 9.14 Seconds - 1GB Upload in ~3 Hours - 16X faster than 56K
This test of exactly 579 kB took 5.184 seconds to complete
Running at 42% of hosts average (Bright House Networks)
I also tried speediest.net:
Ping 18ms
DL 9.SS Mbps
UL 0.97 Mbps
I know that the ISP checked a white connector box in our garage and the connection in the room, but not sure if he checked any outside connections.
The numbers I am getting when attached to the modem I believe are normal.
Message 3 of 11
readysecure1985
Could you log in to the router and set the WiFi to G only and throttle it to 54? Unless all your devices are N capable it can cause erratic behavior to use N on the router. Since you have already worked with support for both your ISP and Netgear I am going to skip over the cabling troubleshooting parts and startup sequences.
Message 4 of 11
JRojas25
Novice
I can go into the router and I know how to change the channel, but not sure what you mean by throttle it to 54.
Message 5 of 11
readysecure1985
There should be an operating mode in wireless that lets you select the speed it is capable of. If you can try it out with it set to 54 and mode to G it could help with the speeds.
Message 6 of 11
JRojas25
Novice
Actually, I do not know how to change this router to g only. Could you tell me where I can do that? Thanks so much for your help so far.
Message 7 of 11
JRojas25
Novice
I changed it to 54 and could not find a place to change it to g only. Tried another speed test and it is terrible again.
Download Connection:: 428 Kbps or 0.4 Mbps
Download Speed:: 54 kB/s
Validation Link:: http://testmy.net/db/rF7cmob
Test Time:: 2012-06-15 15:14:27 Local Time
1MB Download in 18.96 Seconds - 1GB Download in ~5 Hours - 8X faster than 56K
This test of exactly 256 kB took 4.789 seconds to complete
Running at 4% of hosts average (Road Runner)
User Agent:: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_7_4) AppleWebKit/534.56.5 (KHTML, like Gecko) Version/5.1.6 Safari/534.56.5 [!]
Message 8 of 11
readysecure1985
I am running out of ideas. What type of modem do you have?
Message 9 of 11
JRojas25
Novice
The modem that was given to us is a Terayon tj 715x.
Message 10 of 11
jlewter
Guide
Perhaps I am missing it.
Did you also test the speed by connecting to one of the LAN ports on the 3700 and running a speed test? (disable your wireless on your laptop when you do this).
Testing like this now would help point us towards the 3700's WAN layer or just a WIFI issue.
When testing do you see a lot of packet loss?
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 3865 views
  • 0 kudos
  • 3 in conversation
Announcements
