Discussion stats
  • 1 reply
  • 1529 views
  • 0 kudos
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
Follower
IP address filtered, unable to connect after removing
I looked into my router settings and I noticed my iPhone was on a "filtered" list blocking it from accessing the Internet. I have removed it but it keeps saying I have the wrong password when I try to reconnect on my iphone. I recently changed my wifi password but my new or old one isn't working.
Message 1 of 2
Highlighted
Re: IP address filtered, unable to connect after removing
If my Android device is anything to go by, your iPhone has remembered the local wifi settings.
To get it to use your new settings, you need to tell your iPhone to forget that is has connected to your local wifi. Then when you try to connect it will ask you for the password.
I'm afraid I don't know how to do this on an iPhone. It is in the wifi settings on Android.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
