Reply
Improved DLNA performance?
TrondS
Is there anyway to improve the performance of the DLNA feature? I have a Galaxy Tab 10.1 that I'm using to stream some video from the WNDR4500, but the buffering is a pain, and often the video freezes only to run at double speed for 1-2 seconds.
Message 1 of 3
Scubbie
Apprentice
Re: Improved DLNA performance?
I have a Samsung Galaxy S2 and WNDR3800. My phone only connects using a single channel on either the 2.4GHz or 5GHz channels. You may wish to check the specs of the Galaxy Tab.
Also download and install 'WiFi Analyzer' from the Google Apps Store. This will allow you to check the signal strength of the router from where you are viewing the content.
Message 2 of 3
oskingen
I have the same problem on my XBOX. The performance is very bad.
My xbox is close to the router, around 2 meters. Sometimes I have to reboot the router
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2967 views
  • 0 kudos
  • 3 in conversation
Announcements
