Reply
Installation Issue with WNDR3400
JohnT311
Follower
Installing new N600, WNDR3400 Wireless Router through Speedstream 6520 Modem. Connected to Internet with no problem. Installation prompt asked to "Check for Firmware Update". Process started fine and about midway through update got message "Firmware Corrupted". Per instructions, used Resource CD to restore Firmware. Router would not recover and Power LED is still in "Slow Flash" Mode.
Any suggestions would be appreciated. Don't know if there is anything else I can do, or did I just get a bad Router and need to take it back to Walmart for another one.
Message 1 of 4
jmizoguchi
Virtuoso
Re: Installation Issue with WNDR3400
I would get exchanged.
try reset the router but more than that for new products, get exchanges
see router reset on my sig below
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 4
yoog1
I have an issue with seeing a lower signal for the 5ghz. I see a stronger signal on my 2.4ghz. I'm using a new macbook pro. Can somebody help me?
Message 3 of 4
jmizoguchi
Virtuoso
5ghas Hals LESS range at same distance what 2.4GHZ
This is nature of how both band works. Nothing to do with router itself
Suggest to use 2.4Ghz/300mbps in the router's setting
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 4
Discussion stats
  • 3 replies
  • 4699 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
