tonyayling's avatar
tonyayling
Follower
Jun 08, 2021
Installing Joomla 3 on ReadyNas Pro 2
Hi
I would like to install Joomla 3 on my ReadyNas.  I have installed the App by Poussin, it upgrades well to 3,59 then the next upgrade requires PHP 7.  I installed MXtras version of PHP 7 but that deletes the Joomla App.
Any help gratefully recieved.
Thanks
Regards
Tony AYling
1 Reply
  • michaelkenward's avatar
    michaelkenward
    You have posted your message in the section of this community given over to General WiFi Routers (Non-Nighthawk). (This is easily done, given Netgear's complicated community structure.)
    Many questions apply to different types of device, so you might get responses here, but the ReadyNAS Pro 2 is nothing like a router, so you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
    ReadyNAS Network Storage: Official NETGEAR Community
    I will ask the Netgear moderator to move your message.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear gave up on supplying paper manuals years ago and people sometimes miss the downloads.
