Reply
Is WNDR3700 right for our customers?
wzhangnewport
Hello anyone who will help,
since our company is going to hava a wifi transmitter and we would like to recommend our customers the Access point/routers.
We tested WNR2000, everything is good, except the WNR2000 is not immediately transfer after finishing 4 way EAPOL key handshark. it needs to wait about 20 -50 mini seconds.
Ques:
1) Does the WNDR3700 have the same issue after 4 way EAPOL ? or not?
2) which Access Point/Router does not have this issue? could you recommend?
thanks
wendy
Message 1 of 3
jmizoguchi
Virtuoso
Re: Is WNDR3700 right for our customers?
Lookat prosafe routers for bussiness clients
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 3
wzhangnewport
Large percent of our customers are home customers. and we have found a linksys AP and dlink AP are good, and we would like to find a good from Netgear also to recommend. The only issue with Netgear is that after EAPOL key handsharking, the Access Point did not immediately transfer data, it needs wait more mini seconds, and try again.
Do you know which home model will not have delay?
thanks
wendy
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2691 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
