× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Is it possible 2 change Netgear R6300 v1's router's guest WAP's channel?
ant
Prodigy
Prodigy
I don't see an option to change it. Only on non-guest sides. This is using the (lat/new)est firmware v1.0.2.80_1.0.59.
Thank you for reading and hopefully answering. 🙂
Model: R6300v1|Dual Band Gigabit Wireless Router - 802.11ac
Message 1 of 3
Accepted Solutions
antinode
Guru
Re: Is it possible 2 change Netgear R6300 v1's router's guest WAP's channel?
> I don't see an option to change it. Only on non-guest sides. [...]
   I'd guess that that's because there is no way to do it.  On these
routers, the "guest network" is implemented as a set of firewall-like
rules to restrict "guest" clients; there is no separate "guest" radio
with its own radio channel.
Message 2 of 3
All Replies
antinode
Guru
Message 2 of 3
ant
Prodigy
Prodigy
Ah, thanks. 🙂
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 987 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
