Reply
Just got IPOD Touch and can't connect on wifi :(
mmamorr
Follower
I called Netgear and they said laptops and printers are network devices which are working well, but that itouch, ipad, xbox etc are recreation devices which need to be correctly set up in order for my ipod to get the wifi connection. They stated they weren't able to help because my router is over one year old and no longer have service support with them...I NEED HELP PLEASE! How do I set up my router to support my new ipod? I tried putting in the MAC address where it said Router MAC address on the routerlogin.com page but it didn't help...would greatly appreciate the help...please!
Thanks in advance
Message 1 of 5
jmizoguchi
Virtuoso
Re: Just got IPOD Touch and can't connect on wifi :(
like we suppose to know what model of router you have...
detail is ONLY key at forum... Smiley Happy
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 5
MerlinVI
Hello there,
Try this it worked for me on the same problem(dgn2000 router).
Reset the ipod touch and reboot the router(reset all on ipod).
Once you have reset ipod it will reboot leave it for a second untill the router has finished reboot then enter your password for the network you wish to connect to.
You should after entering this be able to connect and spend all your money on apps for it hehe hope this helps you my friend.....Merlin out.
www.thevi.isgreat.org
Gamers against Hax.
Message 3 of 5
Burnz
Don't use Apple software massively but - Ontop of that, just check the IP on the Ipod matches the 1st/2nd/3rd octet of the routerIP/Default Gateway.. eg if its a typical netgear class C it would likely be 192.168.0.1, so check that on the ipod it has a 192.168.0 address to work (the dhcp will assign the last digit for you).
If they've been saved manually in the past, they may stick. But like Merlin said, a master reset would resolve this anyway. Its more a case of "if you don't want to lose data".
Message 4 of 5
jmizoguchi
Virtuoso
Not sure how you are going to do with iPad,touch,iPhone
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 5428 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
