Reply
Just will not connect - wifi on DS Netgear DG834G
Mars Mug
Virtuoso
Re: Just will not connect - wifi on DS Netgear DG834G
If it is a compatibility issue I would expect to find many cases in a simple Google search 'DS wireless DG834G' I found nothing that related to the problem of not seeing the SSID.
Message 26 of 40
StressedMum
'I don’t think you need to worry about IP addresses yet, until your DS is able to see it' - If I am manually setting up DS I have to put in an IP address - now I used different ones for the other items starting from 01 - 200+. So, should I put in 1 or ?
Message 27 of 40
Mars Mug
Virtuoso
IP addressing doesn’t come into effect until your DS has connected to the network, at the moment it can’t even see the network. If it ever does manage to see the network and connect then I expect you would see error messages on the DS relating to IP addresses. Sorting out the IPs should be easy if we ever get that far.
Message 28 of 40
StressedMum
ok Andy - think I am understanding now - a little! :confused: I'm leaving this now for today - been at it about 24 hours! :mad: Will have to try and borrow another DS and see where we go from there... Thanks for your help. SM :rolleyes:
Message 29 of 40
jmizoguchi
Virtuoso
just world of wireless :):)
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 30 of 40
StressedMum
Well, well, well..... I've done it! Went to Router page, maintenance and download the latest FIRMWARE - hey presto - we're up and running! Found that info on a site somewhere which I can't find again now - but thanks to whoever it was for the link and thank you to everyone who has helped on this forum. Not so SM ! 🙂
Message 31 of 40
jmizoguchi
Virtuoso
guess we all may forgot about firmware... 🙂
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 32 of 40
Mars Mug
Virtuoso
StressedMum wrote:
Well, well, well..... I've done it! Went to Router page, maintenance and download the latest FIRMWARE.....
OH NO, you didn’t update the firmware did you? But …….. just kidding. Glad you’re sorted. 😄
Still, pretty strange that only the DS could not see the SSID? :confused:
Message 33 of 40
jmizoguchi
Virtuoso
you are on funny side today Andy.... man.. UK people.. they are so crazy!!! 😉
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 34 of 40
purplegerkin
hey, ive had the same problem with my ds, and its really annoying, i have the same model router also
i was just wondering where the firmware update can be found? id really like to be able to connect ot the internet, and soon!
Message 35 of 40
jmizoguchi
Virtuoso
http://kbserver.netgear.com/downloads_support.asp
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 36 of 40
purplegerkin
hmmm tried updating, but my ds says that
the access points security settings are not supported by the nintendo ds
i think im goin to have to change router 😞
Message 37 of 40
purplegerkin
ha, just solved the problem, ds's only recognise WEP password thingys, not the other type we were using, i have changed it and it works! yay!
here is the link to the forum i found the info on, in case anyone else has the same problem
http://infovore.org/archives/2005/11/28/getting-mario-kart-ds-online-with-a-netgear-dg834g/
Message 38 of 40
Okami_Hoshi
I am having issues being able to connect my DS to a Netgear router as well. I see the ssid for the router, it shows that the connection is locked, and even when I put in the right password and it still wont let me connect, it gives me a "These settings are invalid" error.
Message 39 of 40
jmizoguchi
Virtuoso
this 2years old thread.
DS usually only support WEP or WPA depending DSL model.. check nintendo site for which encryption supports.
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 40 of 40
Discussion stats
  • 39 replies
  • 13155 views
  • 0 kudos
  • 6 in conversation
Announcements
Orbi WiFi 6E
