Reply
Highlighted
Novice
Keyword/Domain Blocking Problem
Using a WNDR3700V4, latest firmware.
The Keyword/Domain blocking is sporadic. If a device/browser has previously visited and logged onto a blocked site (such as plus.google.com), blocking doesn't work. If there is no history of logging on the site is blocked.
Thanks,
Mike
Message 1 of 5
Highlighted
Virtuoso
Re: Keyword/Domain Blocking Problem
Make sure you are not accessing an HTTPS website as it will not work since it will only block HTTP sites.
Message 2 of 5
Highlighted
how do i block the https site? this is pointless if it doesnt block it! I want to block youtube in both the http and the https versions. please tell em how i do that. thanks
Message 3 of 5
Highlighted
Guide
LPC is probably the best solution.
As said, you need time for the DNS values stored in the computer to clear themselves out.
HTTPS is "Secure" so the router cant view the packet data for that and block it. It can block the initial DNS request (as those are sent in plain text).
Sadly the 3700 doesn't allow IP range blocking, and that's what you probably need here.
Message 4 of 5
Highlighted
Virtuoso
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 9671 views
  • 3 kudos
  • 4 in conversation
Announcements
