Reply
LB1120 setup troubles with connection
Stephen2566
Follower
I just got a netgear lb1120 for Christmas for use with my Google Fi data sim. When I followed the setup though I've run into a few issues that I think might be connected.
1. The power LED flashes from amber to green on and off again even though the The bars off to the side will stay green.
2. I can't connect to 192.168.5.1 to even get to the settings.
I've tried factory reseting it as well as making sure the sim card is seated correctly. What does the alternating led light mean? It doesn't say anything in the user's manual
Model: LB1120|4G LTE Modem
Message 1 of 2
Re: LB1120 setup troubles with connection
You might get better and quicker replies, and find other answers, over in the appropriate section for your device:
Mobile Routers, Hotspots & Modems
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 678 views
  • 0 kudos
  • 2 in conversation
Announcements
