Reply
Looking to repurpose WNDR4500, will this work ok?
irritated_user
Hi,
I've got a Nighthawk X6 R8000 connected to a cable model.  On another floor I have a TiVo and another network device that I need to pull files off of (large files).
I have a older Netgear range extender that works some / most of the time, but dog slow transfers.
I can't connect that to my Nighthawk, so needs to be wireless solution.
I've got an old WNDR 4500 sitting around, thought that might be able to be used as a range extender somehow, like the one I have there today, but (in theory) would be faster.  I saw some comments about this working | not working | being slower than expected because of options to connect it back to Nighthawk.
Option # is a PowerLine adapter, but wanted to get feedback on repurposing the WNDR first, as it'd be free - definitely has the WAF box checked.
Thanks,
Chris
Message 1 of 4
TheEther
Guru
Re: Looking to repurpose WNDR4500, will this work ok?
What's the model of your Netgear range extender?
The WNDR4500 won't work as a range extender but you could use it in this kind of set up:
R8000----[Wi-Fi]----Extender----[Ethernet]----WNDR4500 in AP Mode----[Wi-Fi]----TiVo
The idea is to place the extender closer to the R8000 and the WNDR4500 closer to the TiVo.
Message 2 of 4
BARNES
Apprentice
https://www.dd-wrt.com/wiki/index.php/Netgear_WNDR4500
http://www.dd-wrt.com/wiki/index.php/Client_Bridged
DD-WRT in Wireless Bridge mode would do the trick...TIVO or DirecTV probably wouldn't even push an N connection...
Of coarse I'm assuming these devices on the other end have Ethernet connection...
Message 3 of 4
irritated_user
Thanks, I'll check that out.
Yes, most of the time it's OK, but when I'm trying to do have two streams and / or my wife wants to stream something else to the TV, it starts to break down.
Just figured it was work looking to repurpose the WNDR if it'd get me a bit better performance.
Again, thanks,
Chris
Message 4 of 4
Discussion stats
  • 3 replies
  • 2479 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
