- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Model Number: JWNR2000V2 - N300 WiFi Router. Brief Summary: I need help in limiting internet speeds
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Team,
I am not a tech-savvy person so need your help in limiting speeds for attached devices to router.
I checked my internet speed coming from my Internet Service provider. Both Download speed and Upload speed are somewhere around 4 MBPS, But still I face low internet speed on my laptop.
In my home, four members connect to Wi-fi router mostly by mobile phones and they see netfix vidoes or movies etc. due to which my laptop internet speed is low and therefore I cannot work properly on my laptop. I do sype calls -audio and video calls, then use some online softwares/portals to do my work.
By reading on some articles, I used QoS, but it only allows priority like low, normal, high or highest. But still members can see netflix movies without any interruption whereas I face low internet connectivity on my laptop.
Thats the reason, I asked for the help. Is there anyway where I can limit internet speeds of attached devices or set any particular bandwidth for all devices. Also, please guide me what speed limit or bandwidth should I keep for my laptop (seeing my work I mentioend above) and for others who use neflix or other online apps for movies. Prioirty is my work on laptop.
Thanks and regards,
Prats
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Prats wrote:Hi, Thank you for the sugestion. So what is the recommended internet speed for the work? it depends on what you do for work for what speed you need. If you're a graphics/video specialist, you'll need much higher bandwidth. If you've got an IT department at your work, check with them what they'd recommend for your specialty.
And regarding my query, I still want to understand how can I limit internet speed for other devices. Can you please also reply on that.---- i don't think you can limit with that device. You can set priority by device but I dont' see any bandwidth limiting.
it was manufactured in 2011 and was a very basic router when it came out. Its behind on features, security, and performance. I'm actually a bit impressed its still running after 9 years.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Model Number: JWNR2000V2 - N300 WiFi Router. Brief Summary: I need help in limiting internet spe
Ouch. 4mbps speed isn't very good.
If you NEED it for work, i'd disconnect all the other device entirely while you're working. that's going to be your best bet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, Thank you for the sugestion. So what is the recommended internet speed for the work? And regarding my query, I still want to understand how can I limit internet speed for other devices. Can you please also reply on that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
So, the moral of the story is there is no feature of limiting speed in thsi router. Thank you for the support and guidance.
Yes, it is still running very well, no disturbance till now.
User | Count |
3 | |
2 | |
1 | |
1 | |
1 |
