Reply
Model R6100 Wifi Router won't allow wifi access
Rosscos
I bought this router early spring and all of my laptops and tablets can access wifi connection but one laptop. This laptop will access other wireless conenctions (work, etc) but has never worked with this router since I bought it. I have called customer service with no answers to the problem. Anyone have any ideas what I need to do? Thank You Teresa
Message 1 of 9
Babylon5
NETGEAR Employee Retired
Re: Model R6100 Wifi Router won't allow wifi access
The most likely option in the router settings that may prevent a laptop connecting is the Wireless Access List, but since you have many devices able to connect I would guess that you don’t have that enabled (default off)?
Otherwise the symptoms you describe are more likely to be caused by the laptop settings e.g. the laptop may be set for a static IP address; this should be set to automatic. http://windows.microsoft.com/en-gb/windows/change-tcp-ip-settings#1TC=windows-7
Does your laptop detect your wireless network in a scan?
____________________________
Working on behalf of Netgear
My name is Andy
Message 2 of 9
Rosscos
I tried to look at all of the setting again. Here are a few screen shots maybe I am missing something? Thank You
Message 3 of 9
Rosscos
another screen shot
Message 4 of 9
Babylon5
That first screenshot shows that your WiFi adaptor has successfully associated with the router and has obtained IP data. The WiFi Status screenshot however shows 134 packets sent but none received. It seems to me that something may be blocking incoming traffic, a firewall perhaps? Do you have any firewall software running on the computer, and can you temporarily disable it?
If you go to a Command Prompt and type Ping 192.168.1.1 do you see any responses?
My name is Andy
Message 5 of 9
Rosscos
Is this what I need to be looking for?
Message 6 of 9
Rosscos
Message 7 of 9
Babylon5
You have your network set as ‘Guest or public’, you might be better off changing that to ‘Private’; https://tinkertry.com/how-to-change-windows-10-network-type-from-public-to-private
My name is Andy
Message 8 of 9
Rosscos
I just thought I'd let you know that my problem is finally fixed. None of the above suggestions did they trick. I did some searching and saw where several were having problems connecting using Windows 8. I upgraded to Windows 10 last night and BINGO - It now has conenction to Netgear!?!?!? Thank You!
Message 9 of 9
Discussion stats
  • 8 replies
  • 3257 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
