Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2013-01-15
04:03 PM
2013-01-15
04:03 PM
My PSP cannot connect to WLAN
Hello,
My PSP cannot connect to WLAN, because when I'm trying to connect, it shows me an error:
My router is WNR1000v2. I tried to connect without any security and with WPA-PSK [TKIP] + WPA2-PSK [AES]. Error shows again and again.
A connection error has occured. A connection to the access point could not be estabilished. Check the security settings fot the network and try again.
Message 1 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2013-01-15
04:12 PM
2013-01-15
04:12 PM
Re: My PSP cannot connect to WLAN
Questions is PSP worked with same setting or you are adding as new to the network?
Suggestion is also try different wireless mode and wireless encryption combination
For example , PSP-3000
http://us.playstation.com/psp/techspecs/3000cp.html
supports Wireless LAN (IEEE 802.11b) (Wi-Fi) which means wireless mode using higher than 54Mbps may not going work ..
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
VPNCASESTUDY.COM
June Mizoguchi-
Message 2 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2013-01-15
04:14 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2013-01-16
07:26 AM
2013-01-16
07:26 AM
I tried connect using WEP and 54Mb/s mode but it shows me an error, other than previous:
A connection error has occured. The connection to the access point timed out.
I don't know, I bought it in used condition.
"Sherry07" wrote: How old uis your PSP?
Message 4 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2013-01-16
07:37 AM
2013-01-16
07:37 AM
You start off unit with unit you don't know.
If you can not use setup using 54Mbps then you may possible got wifi.
Have you tried other wifi at like your friends place to determine that you go defective PSP on wifi?
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
VPNCASESTUDY.COM
June Mizoguchi-
Message 5 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2013-01-16
11:58 AM
2013-01-16
11:58 AM
I have this PSP almost two months.
"jimizoguchi" wrote: You start off unit with unit you don't know
"jimizoguchi" wrote: Have you tried other wifi at like your friends place to determine that you go defective PSP on wifi?
Yes, I checked wifi in my school and wifi tethering shared by my smartphone and it works fine.
Message 6 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2013-01-16
12:23 PM
2013-01-16
12:23 PM
I can only that if works on other wifi and tethering and tried WEP/54Mbps already then I think you got compatible problems.
You options are to find 802.11G Access point install behind the your WNR1000 so that you have support for legacy devices
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
VPNCASESTUDY.COM
June Mizoguchi-
Message 7 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2013-01-16
02:26 PM
2013-01-16
02:26 PM
jmizoguchi, what do you mean, when you say: "compatible problems"?
Message 8 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2013-01-16
02:36 PM
2013-01-16
02:36 PM
Exactly the word means
Doesn't like each other. This happens with legacy 802.11g and n router
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
VPNCASESTUDY.COM
June Mizoguchi-
Message 9 of 9
