Reply
N300 WiFi router model WNR2000v5 won’t connect to the internet after firmware update
aab35
Follower
My router won’t connect to the internet after a firmware update. Tried also the resets. Can’t connect directly to computer because I don’t have an Ethernet port, but the modem looks fine and all the lights are on, there’s just no WiFi signal.
Model: JWNR2000v5|N300 Wireless Router
Message 1 of 2
antinode
Guru
Re: N300 WiFi router model WNR2000v5 won’t connect to the internet after firmware update
> [...] WNR2000v5 [...]
   Which model?  Look at the product label.
> My router won't connect to the internet after a firmware update. [...]
   How did you do the "a firmware update"?
> [...] there's just no WiFi signal.
   The WNR2000v5 won't connect to the Internet, or your (unspecified)
"computer" won't connect to the WNR2000v5, or what?
> [...] Can't connect directly to computer because I don't have an
> Ethernet port, [...]
   Obtain the use of a computer with an Ethernet port?
> [...] the modem looks fine [...]
   What is your "the modem"?  What does "fine" mean to you?
> [...] and all the lights are on, [...]
   "on" is not a color.
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Read.  Look for the LED
descriptions and "Troubleshoot".
> [...] Tried also the resets. [...]
   Which "the resets"?  After a settings reset, any old wireless-network
settings would be reset to their default values, which might cause
trouble.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 450 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
